Calibration issues
  • Calibration issues
    I’m having major calibration problems.
    I’m running 4.2 MR1 with a Sheffield. Everything was working fine. Was running a program checking a part when pc-dmis just closed. No error message. I rebooted everything and restarted pc-dmis. Probe files were there but nothing defining the probe and no angles.
    I rebuilt my probe & added angles. I calibrate using Man+DCC it works for about 9 or so angles then I get an error stating the measurement is to far out for the particular angle.
    I can make it work with using up to 6 or so angles but if I add more it won’t work.
    Sometimes it’ll work doing Man+DCC but when I go back to DCC+DCC the probe will completely miss the ball during normal calibration after 6 or so angles. It isn’t the same angles messing up either.
    I’m thinking that something is corrupt but don’t know what else to do.
    Any ideas?
    Maybe you had a "bump" and the probehead is no longer square with the machine.
    Lately, it occurs to me
    2017 R1 (Offline programming)
      delete that probe file, then rebuild and try again......sounds like a corrupt probe file
      Originally posted by Ironhoe
      I got something under my sporran for you, take care of it and you got my vote.
        What file is it I delete?
          Probe1.PRB
          Probe1.Results
          Whatever your probe is named....
          Global Performance
          5-7-5, PH10T, 4.2-1
          Micro Xcel 7-6-5
          PH6, 4.2-1
            I deleted the probe files *.prb & *.results. Built a new probe file. Added A0B0 ran calibration, told it the ball moved and took the first hit on the top of the ball. Everything was perfect. I then added A7.5B0, 90, -90, 180 and A45B0, 90, -90, 180 & A67.5B ..... & A90B ...... Measured all, told it the ball was moved took the first hit and let it rip.... It did A0B0 & All A7.5B.... Did A45B-90 all fine and missed the ball by .250 on A45B0.
            I have no idea what else to do.
              Create your probe file with nothing apart from A0B0.
              Calibrate it once using man+dcc after telling it the ball moved.
              Then add all the angles you need then calibrate the full probe using dcc+dcc.
              You ONLY tell pcdmis the ball/artifact moved if you ACTUALLY MOVE IT.
              If you dont move the **** thing, then dont tell it you did.
              Roses are red
              Violets are glorious
              Don't try to sneak up
              On Oscar Pistorius.
              MIL-TFP-41C
              3.7mr3, 2012mr1, 2013mr1
                Calibrate again and closely watch each hit.
                Does the probe seem to be going where it should? Or, does it seem to be off-center.
                If your probehead has been bumped and is no longer square with the machine's axes then the further you get away from 0/0 the more "shifted" it will look until finally it will miss the sphere.
                  Or if you re-home the machine. Homing resets the CMM's zero point and has the effect of moving everyting on the table.
                  v2013 MR1, v2015.1
                  B&S Global 544, 555
                  Mitutoyo A504 w/PC-DMIS
                  Since 1994
                  (Advice from my dad.)
                    I called Support and got it working with a work around after 3 hrs. To add angles I have to manualy calibrate the angel with 5 hits then do DCC+DCC. After I do it manualy with that angle it will do DCC+DCC from then on. (so far...) Richard @ tech support did a fine job.
                    Thanks for all the help online.
