cant seem to get the paremeters right to calibrate and use 3mm probe 90 degrees on 0,0
knuckle calibration
Originally posted by psalm2cant seem to get the paremeters right to calibrate and use 3mm probe 90 degrees on 0,0sigpic"Hated by Many, Loved by Few" _ A.B. - Stone brewery
I think Paul is right. Make sure you see the proper configuration in the window. I would also suggest again that you try the single tipped star probe method of defining the probe. I am attaching a screen shot of my build. HTH
Last edited by Wes Cisco; 05-25-2007, 11:12 AM.sigpic"Hated by Many, Loved by Few" _ A.B. - Stone brewery
by Tim HindsmanI need to measure some features on the bottom of my part. I have a M2 knuckle in my inventory that I would like to use. I am running PC-DMIs 2015. My...
09-24-2016, 02:08 PM -
by RavenmaniacGood morning fellow prisoners of the overworked, underappreciated sect of quality. Questions....(it's hard to believe it but I've never done one of these...
08-27-2009, 10:36 AM -
by Addison WoodRunning a PH10MQ with an 30mm to 8mm converter, TP20, 20mm M2 extension, M2 Knuckle, and a 1X20mm probe.
When the PH10MQ is at 0,0 I want...-
05-09-2007, 12:03 PM -
by Dml989All,
This is the first "star probe" I've worked with so far. I built it in the probe utility box. I am unsure if I have built it...-
02-15-2017, 10:26 AM -
by hammerI am having trouble with star probe calibration I am only using 2 tips locations 1 and 5 and using all angles b-90 and b90 so I have to use 2 calibration...
10-25-2007, 03:27 PM -
