Warning Message Options v4.1?
  • Warning Message Options v4.1?
    Just installed v4.1, and I'm more familiar with v3.7MR2.
    However Im getting those pesky messages again like:
    "Save theo values as new target?"
    and
    "Do you want to update the measured values also?"
    I want to set my default response to these warnings and then stop seeing them altogether? In 3.7 these were in the warnings dialog box after clicking on Setup, but ever since I installed v4.0/v4.1 there are only 3 warning messages shown in the warnings messages location to be able to select options for?
    Where these warning options moved to another location in the latest releases for the software, and could someone tell me were to change the options for the above two.
    Thanks,
    Mr. Comment
    SCIROCCO-NT 13-20-10
    In the setup under warnings you can turn them off.
      I talked with Support today and I guess, I cant turn these warnings off until the next release of PC-DMIS.
      I cant turn these warnings off in v4.1 because they dont exsist in the Edit>Preferences>Setup>Warnings Dialog box. Neither is there a checkbox on the warning message to disable it.
      Mr. Comment
        Another quality product.
          Not suprising.
            The Warnings dialog box only gets populated when you turn a message off. This was a design change made in 4.0 and later. This is discussed in this thread here:
            http://www.pcdmisforum.com/showthread.php?t=1579
            As discussed in that thread, some messages didn't get a "do not display again" check box when they were converted over to the newer format and as you say don't show up in the Warnings dialog. WAI is aware of the problem. Hopefully for 4.2 this will get resolved.
