New job... new problems
  • New job... new problems
    I am having a problem with 1 machine with 2010 loaded. While programming and executing, the edit window changes from command mode to summary mode by itself no matter how many times I switch back to command mode. I've searched the threads but came up empty. Any solutions? Would appreciate!
    I am fluent in three languages:
    English, Sarcasm & Profanity.
    When program is running, stop it, change to command mode and press continue.
    sigpic...engineering
      set edit window to desired mode, then F5 setup/general tab....
      'use program layout for execution'
      HTH
        Will check it out when I can... Different building today. Running 2011 here. Thanks for all the input!
          “TreatTheoValuesAsIfStoredInPartCoordinates” box unchecked? Also, if your running 2010MR2 there is a bug again with the snap fuction, so if your using it, for some reason it changes your theos to whatever it measured. Try turning it off.
