I have a check fixture for a stamped sheet metal part that I need to verify. It is designed to use a feeler gage around the edges to check the profile. I have CAD for the part but not the fixture. I do not have access to a 3d drawing program. What I would like to do is use the CAD to create points, offset them 3mm along their normal vector and then flip the vector so I can check the surface profile of the fixture using nominal part data. How would I go about this?
checking a fixture using part CAD
by Thiyagu_Rajhi everyone,
my boss is asking me to check profile of a surface for a bending fixture using part model ,is it possible to check ????? as...-
01-04-2017, 11:51 PM -
by Jonathan SI have a fixture to inspect that checks profile of a stamped part. The profile of the fixture is offset from the nominal by 3mm so that a go/no-go feeler...
05-04-2006, 04:38 PM -
by MsolitoI have a Cad model (IGES)file and I need to check this fixture gage, but the cad file match with fixture but the blue print don't is around .35mm longer...
01-20-2009, 01:08 PM -
by zachshackleyHi,
I am trying to write a program for a part that has to be clamped down in a checking fixture, the fixture has datum holes and shows how they...-
05-31-2017, 05:14 PM -
by chasmanianI am new to PCDMIS, GDT, and this forum, so please forgive me.
A customer wants me to measure a part in a constrained position measuring...-
07-12-2010, 01:44 PM -
