We have a Microval Pfx with pcdmis ver3.0864 that we are having a few problems with. I am wanting to know how close this machine and software can check an angle. A little bit more info on the machine, it is a manuel machine with an older computer. We have a part for a customer of our the we have to check an angle within 9min. Is this machine capbable of that or would be wasting time and money on this. Would a dcc machine be much more capable of checking the angle with the tolerance we have? We are trying to find the best way to do this. Thanks for your time.
Angle Checks
Originally posted by Darren JohnsonWe have a Microval Pfx with pcdmis ver3.0864 that we are having a few problems with. I am wanting to know how close this machine and software can check an angle. A little bit more info on the machine, it is a manuel machine with an older computer. We have a part for a customer of our the we have to check an angle within 9min. Is this machine capbable of that or would be wasting time and money on this. Would a dcc machine be much more capable of checking the angle with the tolerance we have? We are trying to find the best way to do this. Thanks for your time.
How much of an angle are you checking. It its like 35 degrees then you would be hard pressed to check on a manual machine. I know of no way of compensating for the sin error in your hits. A dcc machine is the way to go. My .02sigpic.....Its called golf because all the other 4 letter words were taken
It isn't even hitting the same points thats a problem. The problem will be cosine error. If you aren't vectoring into the touch on the vector of the surface you're measuring, you're inducing cosine error into your measurement. The ruby isn't hitting the measured surface on it's equator. For a tolerence like the one you're trying to hold a manual machine is a total waste of time in my professional opinion.
Bill
You could alway set up a 35º angle with a sine bar and measure to see how repeatable you are. While that won't necessarily give you and answer to overall accuracy it will tell you if your repeatablility is outside of +0 -4 min.
So, if you can't repeat within say 15 min then I definitely would not trust the results.
Originally posted by GoodluckYou could alway set up a 35º angle with a sine bar and measure to see how repeatable you are. While that won't necessarily give you and answer to overall accuracy it will tell you if your repeatablility is outside of +0 -4 min.
The machine is accurate enough to measure what you need. It is just a matter of skill and technique. Practice until you get it right.
Originally posted by Bill McCaffertyIt isn't even hitting the same points thats a problem. The problem will be cosine error. If you aren't vectoring into the touch on the vector of the surface you're measuring, you're inducing cosine error into your measurement. The ruby isn't hitting the measured surface on it's equator. For a tolerence like the one you're trying to hold a manual machine is a total waste of time in my professional opinion.
Bill
I agree that the tolerance is demanding (±0.033º) for most features, and in the hands of the wrong CMM operator of a manual machine problems could arise. However, I must say that a manual machine will comp well and cosine error will be very clean (practically non-existent) on a plane. Manual machines are great and even better in the hands of an astute operator. If you have a manual machine give it a try. Go ahead and vector poorly to a plane and check your results. I grew up on manual and I do realize you can get negligibly more accurate results when vectoring properly (how much better depends on the feature type) but the comp math in PCDMIS and most microprocessor controls does a very nice job with 3D features.
Originally posted by craiger_nyHowever, I must say that a manual machine will comp well and cosine error will be very clean (practically non-existent) on a plane. Manual machines are great and even better in the hands of an astute operator. If you have a manual machine give it a try. Go ahead and vector poorly to a plane and check your results. I grew up on manual and I do realize you can get negligibly more accurate results when vectoring properly (how much better depends on the feature type) but the comp math in PCDMIS and most microprocessor controls does a very nice job with 3D features.
Craig
DuaneXcel & MicroVal Pfx & Global 37mr4 thru 2012mr1sp3
Contura Calypso 5.4
by JacekI was asked by customer what is the accuracy of an angle of our CMM. Volumetric MPE stated for our machine is 1.7+(4L/1000).
Is there any formula...-
10-11-2014, 10:24 AM -
by chadjacChecking a female taper angle with a tolerance of +/- 01'15" (about .02 degree). Company doesn't want to spend the $ on an airgage. Does the CMM...
08-12-2015, 09:59 AM -
by Jim PoehlerGood morning,
Something new here, a position call out for an angle to be .001 to datums A and B. Anyone here experience this before and how would...-
10-02-2014, 09:50 AM -
by mdobb829Can anyone tell me how I can force a reported ANGLE to the angle call out on the print? I have a 15° angle call out on the print. When I ask for the...
08-01-2008, 05:01 PM -
by orion
on my program i have
LOADPROBE/TOOL 6
TIP/T1A60B180, SHANK IJK 0,-0.866,0.5 ANGLE=180
04-12-2014, 06:42 AM -
