Turn off the dist approach
  • Turn off the dist approach
    Version 3.7 MR2, with CAD model.
    Technical question!
    I am measuring vector points with a 10mm dist approach and retract.
    When I go to investigate the point on the CAD model I have a 10mm green line that is representing the approach vector distance. How can I turn this graphic off without turning off the approach/retract distance - or should I start a poll?
    Bristol Citysigpic
    Home of the Reds
    You can change your prehit and retract by using F10 and under Tab Motion.
    You can tuurn off the green line in AUto features by clicking on the first of 3 buttons on the same level as your "clearance plane" and "measure" check boxes.
    Hope this helps.
    BS
    Windows 7
    Pc-Dmis 2015
    Global Performance 7-10-7
      In the middle of your auto feature dialog box there is a button with a red circle and green lines. Click it so that it is not depressed. This turns off your path lines. HTH
      Jaime
      sigpicYou're just jealous the voices talk to me.
        Technical question!
        POLL!!!
          Many thanks.
          Bristol Citysigpic
          Home of the Reds
