Hello All
I have an ellipse I.D. 13.7mm & 20.9mm. The I.D is checked at 4.5mm down from a plane. My question is, I need to find the angle of the ellipse from the top to the bottom of the feature which is 7.0mm in depth????
I've created six ellipse's down the 7.0mm and have made points out of all the ellipse touches. I've tried to make a cone and a feature set with no luck. I created a line out of a set of points down one side of the ellipse and tried to dimension the angle to the correct working plane with know luck!!
Does any one have any suggestions?? Thanks
