Probe Active Tip List Errors
  • Probe Active Tip List Errors
    We have been running into a problem with our programs that use the same tip configuration. Sometimes when you open the calibration, you see tip angles added or deleted. When I fix the probe file, the program runs fine, but later when the program is run again, the same issue with missing or added tip angles occurs. The calibration history has been checked and the correct tip was calibrated for that program. This same problem occurs on other programs that use the same tip configuration. Has anyone had this problem before?
    Sounds like a rights issue. . . .make sure you are runningv as an administrator. . . .
