I just switched to 2011 Demon from 3.7 and I have created a feature set out of ten auto points and want to create an analysis view showing all arrows and point locations in the Y axis. This is so that the welders will know exactly where and how far they need to move the tab they are welding on. When I create the analysis command, it only shows one arrow on one of the hits. I have tried to search for the answer, but didn't find a thread about the same problem. Any help would be appreciated.
Graphical Analysis wont show all Arrows on report. Only one
You need to dimension the set with profile (formandlocation) and then apply the graphical analysis to the profile.
Graphical analysis on the set by itself will only show the centroid of the set, IE; 1 arrow.Lately, it occurs to me
2017 R1 (Offline programming)
Originally posted by John Riggins View PostYou need to dimension the set with profile (formandlocation) and then apply the graphical analysis to the profile.
I know I could use some more training all around but i have a question about my results. I dimensioned both the location of the scan and the form and location, both showing my textual hit values for all 10 hits in the constructed scan. my hit values of the idividual hits are not the same in the Y axis comparing from the location dimension to the form and location. My nominal is .875 in the Y direction on the location dimension, and it only reads .005 Dev. The form and location dimension is telling me .028 dev and as i said, the measured values in the Y axis do not match the measured values in the Y axis of the same points. I need some help understanding why the measured values are different. I am using a model and have 2011 CAD++
Originally posted by JThomas View PostI know I could use some more training all around but i have a question about my results. I dimensioned both the location of the scan and the form and location, both showing my textual hit values for all 10 hits in the constructed scan. my hit values of the idividual hits are not the same in the Y axis comparing from the location dimension to the form and location. My nominal is .875 in the Y direction on the location dimension, and it only reads .005 Dev. The form and location dimension is telling me .028 dev and as i said, the measured values in the Y axis do not match the measured values in the Y axis of the same points. I need some help understanding why the measured values are different. I am using a model and have 2011 CAD++
by hemirunnerI don't know if anybody else has had this issue but I create autofeature analog scans and it is about a 50% chance that when I do a graphical analysis...
10-09-2013, 06:45 AM -
by UnderspecCan anyone tell me if I can display in the graphical analysis report, the location of the points? I don't want a list in the report but rather the point...
06-29-2006, 09:59 AM -
by cappy6124Hi all,
i'm trying to use a graphical analysis to show our polishers where they need to hit a part, unfortunately after the analysis...-
02-29-2012, 10:27 AM -
by RobertoHey good morning homies!!
I don't do graphical analysis often and I'm sure this got to be easy.
Look at the attachment, I have...-
07-10-2008, 10:45 AM -
by dccfreakI have a few questions regarding analysis reporting. I kind of get the idea of what it does, but, I have never needed to use it before now. I would...
04-12-2006, 10:49 AM -
