Getting this error now and my controller shuts down. It happens on all my programs. Anyone know why and how to fix it please?
Error 35 - Move Absolute
Sounds like that is a Sheffield error:
Here is what it says about that error:
MP-035 Y-axis counter fault
The amp/check/divide board detected a Y-axis counter fault. If the Y-axis uses a scale and reading head, then possible causes are :
- The gratings are dirty.
- There is too much DC offset.
- There is not sufficient amplitude in the read head signals.
- The read head skew angle is improper.
- The axis is moving too fast (over 40 in/sec.)
If the Y-axis uses a laser interferometer, then possible causes are :
- The laser beam is blocked.
- The laser beam is not properly aligned in the interferometer.
- There is too much DC offset in the OPD lissajous.
- There is not sufficient amplitude in the OPD lissajous.
- The axis is moving too fast (over 25 in/sec.)
What you should do
To clear the error, click Clear error in the XYZ Display window. To clear it using an RCU-II, press and hold down the Servo Power Off button and then press the Joy button twice.
If the axis uses a scale and reading head,
Clean the gratings using a soft, lint-free cloth and isopropyl or denatured alcohol.
Check to make sure the DC offset, amplitude, read head skew, and axis speed are within allowable limits.
If the error reoccurs, call your Giddings & Lewis service representative.
Too late, I uninstalled 4.1 and restored v3.7. I have not had the error since. It's got to be a v4.1 software bug on my machineI used to be high on life but I built up a tolerance.
UPDATE:
Found some gunk on the railing. Cleaned and seems to be working fine now. Hope this helps anyone else out there!I used to be high on life but I built up a tolerance.
by mdconIs anyone familiar with this error? (see attached).
I'm having this problem on our new Micro Height. It's still under warranty. I've been...-
04-02-2008, 11:28 AM -
by JohndkHi,
I'm having problems with my pc dmis. When our CMM is moving, it stops and a message appears on our screen. It says something about...-
12-20-2011, 03:37 PM -
by kysportsterHave a Sheffield 1808 and have error message on the controllor:
a. 122 Fault
b. 034 Fault
Can anyone tell me where...-
02-17-2011, 07:56 PM -
OK, what is taking a dump on my machine when this error pops up? It appears to be in the Z axis, all I need to do it move it ever-so-slightly in the...
05-21-2012, 11:07 AM -
by VinniUSMCAnyone know what a Chip Rate Error is?
This is on my B&S Mistral 7.10., with I dunno what controller (big black one that hangs on the...-
04-14-2016, 11:12 AM -
