Circle Accuracy
  • Circle Accuracy
    I have a Spar that has a ever so slight curve or radius. Its about 20 inches long. I would imagine the diameter to be really huge. I'm trying to get a accurate diameter on it. I'm doing a linear open scan on it and then I'm trying to constuct BF circle from the scan and I'm getting some really bizzare results out of this world. If I measure it normally by taking hit points I get bad results. Is there any way to get a accurate diameter on it? I don't have CAD. Running Ver. 3.2063 on a Validator.
    Thanks.
    Good luck - If you know the theoretical center point, then you could do a polar radius. Are you in aircraft coordinates? If so, about all you can do, if you have surface data, is to dimension point data ( T value).
      A template might be your only option unless you have some fitting software.
      With fitting software, you can take all of the data points and fit them to a theoretical radius of the correct size. It is sort of what Andrew was saying except without the theoretical center point it is very difficult.
        Try using circles around the spar, as opposed to the scan. 3, 4, 5,....20
        Then change working plane to view this arc. Create a circle form the centers of the circles. BTW, when CAD only shows me the two end circles, I use thickness to get different dimension points on a rod. A cylinder scan may not give the definition necessary to create the arc.
          it sounds like your part has a very short section of the diameter......
          that being the case, you don't have much to work with.
          I have been told that you need a minimum of 90 degrees of arc to get any accuracy at all.
          Less than that and the software "sees" a line not a radius
          good luck
          Starrett RGDC 4028-24 :alien:
            good luck
            I have tried this a number of times on some different machines, and have found that you need at a min 30-40% of the dia to get anything remotely close (+/- .010). The way discussed earlier, working from the center and dimensioning each point individually is more accurate.
            "A good design is the one that allows engineers the ability to change gracefully what they forgot to do right the first time!!!"
