When printing to PDF file, I get an error saying "Cannot load PDF drivers, Is CDINTF.DLL installed?"
PCDMIS v4.1 - PDF Driver Issue
The pcdmis install of the pdf drivers may silently fail.
This error occurs because the windows printer installer looks for the file framedyn.dll in the system path and does not find it. This DLL is supposed to be located under the wbem directory under system32 and the system path is supposed to point to that directory.
We have found that under some installations, the system path contains a space character after the wbem directory, which prevents Windows XP from finding this DLL. To check if this is the problem, type PATH in a command line window and check for something like:
path=c:\windows;c:\windows\system32;c:\windows\sys tem32\wbem ;
If this is the case, you will need to manually remove the space from the system path, or copy the framedyn.dll file to your application or system32 directories.
Make sure your path has "c:\windows\system32\wbem" with no extra spaces. Also, is this an X64 system? I do not know when the X64 PDF drivers were added to the install. Possibly late July.
Yes
No
Already tried that
I have verified that file in the system32 and the system32/wbem directory. That still doesn't tell me why or what the CDINTF.DLL file is.I used to be high on life but I built up a tolerance.
print command?
Originally posted by UnderspecFunny that a PDF error would come up also if I have it set to print to an RTF file.
if so it could be set to a pdf.
just a thought.....
by Ken8282Everytime I try to save or print a PDF I get this error message: Unable to load PDF drivers is "cdintf.dll" installed correctly? How would I...
10-10-2012, 01:26 PM -
by Mranaskwhello guys
we have just loaded our programs into new pc everything works fine except that when the measuring is done the "do you want...-
06-15-2019, 01:04 PM -
by wcdr99I am trying to find the pdf drivers. I keep getting "unable to load pdf drivers is cdintf.dll installed correctly? I got this help from support but...
10-18-2007, 12:12 PM -
by JVau425033Has anything seen this error message "unable to load PDF Driver. Is CDINTF.dll istalled correctly?". It ran fne on friday, but not today.:b...
07-05-2011, 04:22 PM -
by LouGeierWe are trying to get a finished report to print out physically from a networked printer and to create a pdf of the report as well. The PDF has to be...
06-06-2012, 11:44 AM -
