offline programming
  • offline programming
    Hello,
    I am a brand new PC-DMIS user I have installed the software at my workstation that is not connected to the CMM. I was told that it should work for offline programming. I am using the Hardlock from the CMM but the New File and Open File icons are not available for clicking. Does this mean that this Hardlock is not capable to use for CMM off line programming?
    Thanks
    teamjnz
    PC-Dmis 3.7mr2
    Brown & Sharpe
    XCEL 7.10.7
    PH10MQ / TP20
    By searching the "Similar Threads" at the bottom of this page you can find the details,
    but a quick answer is. You can offline program, but the computer also has to be hooked up to the CMM, for the lock that came with the Cmm.
    B&S Global 544
    Using 3.7mr3
    Peace
    Greg
      and.....you could buy an offline dongle.
      which is expensive
      sigpicstill core to you
        Originally posted by teamjnz View Post
        Hello,
        Thanks
        Welcome to the forum -
        Get whomever told you it "should" work to show you how it can be done.
        $0.02 - Unless you have prior programming experience and can think in 3-D very good, offline programming is not the best method to learn PCDMIS. When you are offline you can put just about any command you want in a program, but it had better be the right command(s) when the program goes "live".
          It cannot be done the way you were told, period....unless you were using a much older version.
          Jim Jewell
            Welcome aboard! To your question.....we have 4 CMM's here and 2 off line seats. They do not function well without the use of an off line dongle. Swapping out the hardlock of the online machines is not preferred and does not work. I agree with the comments above. As a newbie starting out, you learn more sitting in the drivers seat of the machine.
            Physics dictates to man why his world acts the way it does....Chemistry tells him why it smells the way it does.
            • bigblockv8
              offline programming
              by bigblockv8
              I am wanting to use a seperate computer for offline programming. Does anyone know the requirements on how to do this. Will I need to buy a new software...
              11-20-2012, 12:05 PM
            • Darroll
              Off-line programming
              by Darroll
              Is it easier to program offline? My employer wants me to do offline so that the off shifts can simply run the inspection program. I'm new to offline,...
              08-31-2015, 06:46 PM
            • womer
              Off-Line Programming
              by womer
              My supervisor just asked me a question about off-line programming and I did not know the answer.
              when they bought the Brown and sharoe Global the...
              06-01-2012, 09:19 AM
            • j.gonzalez
              Offline programming
              by j.gonzalez
              I am using 3.7 mr 3 programming offline but for some reason when i excute the program in offline it goes really slow how and where can i adjust thais...
              08-04-2010, 01:48 PM
            • Heming
              Offline programming
              by Heming
              How to set up PcDmis on another computer without a dongle so that I can do offline programming? When I tried, it asks HASP. I beleive it is the do...
              10-27-2010, 08:23 AM
