Hi I have a part to check with some slots that are on the concave surface and when i'm selecting slot with initial hits it's not projecting on to the actual surf.If some one can tell me how to do this I will appreciate.
some help
Hey Guys...Hope you all had a marvelous Thanksgiving...Now back to real life...Anyway, I would normally research this on here prior to pestering you guys...
11-30-2009, 09:20 AM -
by ag162Here is one more,
I have a square slot, it has a recessed area, kinda like a strengthening bead. If I use the auto feature, it attempts to find...-
05-30-2007, 11:00 AM -
by TAC45Is it possible to change sample hit locations for a square slot? There are currently two hits to the left of my slot and one to the right. I actually...
06-11-2019, 08:24 AM -
by gordonI have a rectangular slot 19mm x 25mm to measure in 1mm sheet metal. One end of the slot is formed down about 4mm.
I can sample from the non formed...-
12-03-2008, 01:32 PM -
by hertangelHow do I add more points on the auto square slot. Customer requires 8 points 3 on each side and one top and one on bottom.
Any idea??
06-03-2011, 03:17 PM -
