Are some settings saved in .PRG, if so, which ones, is there any literature on this.
Settings Question 3
Originally posted by RussLAre some settings saved in .PRG, if so, which ones, is there any literature on this.
Some settings that are/can be program specific
move/measure speed,print options,prehit/distances etc."A good design is the one that allows engineers the ability to change gracefully what they forgot to do right the first time!!!"
Thanks for the replies.
We had some issues here, turned out to be one setting in one login on one PC
and a different setting for same login on another PC.
The thought was that someone changed these settings to make the other logins work.
But I know that is not the case, I believe the defaults vary depending on what PC D-MIS you are installing, perhaps what PC D-MIS you previously installed, perhaps on what other applications are installed as well.
I also know from B & S some of the .dat files can get screwed up by trying to open PC D-MIS again, while you are waiting for it to come up (which happens alot here because it can take so long to open the first time).
I was just trying to get a handle on exactly what settings are set where and if you open a file, if some change to those that were saved in that particular file. I believe more info from B & S on this would be very helpful, I believe alot of problems may be settings related.
by Numbers GameRandom question here. While scrolling through the settings editor under the probcal section in search of a particular setting (which I never found) I...
04-05-2017, 03:28 PM -
Below is a response I got from Tech support yesterday. He stated to me in a previous response that changes in SETTINGS EDITOR may have an impact in WINDOWS...
03-22-2017, 07:16 AM -
by vajncI would really like to know if there is possibility of importing the toolbar-personal settings which I have created in PC-DMIS 3.7, from one computer...
11-16-2009, 08:13 AM -
by Tomi530iHi all.
I'm getting new PC for PC DMIS. I'm woundering what files from PC-DMIS should I move from old PC to new PC.
I'm using 2010 MR3 and...-
06-15-2012, 11:13 AM -
by DomPinchottSorry to bring this up, but I have been trying everything for the last day and would love to have this resolved by Monday.
Work requires...-
12-22-2015, 12:03 PM -
