Variable/flow control question
  • Variable/flow control question
    I have a part that needs to be "bin" sorted for matched assembly. ( Customer requirement ) I have 2 measured features that need to be sorted on each part. I have no Issues with assigning the variables and sorting for a single feature but I cannot figure out how to make this process work for 2.
    Example- Part 1 dia1 meas .500 and dia2 meas .250 so part goes in "bin" 1
    Part 2 dia1 meas .501 and dia2 meas .250 so part goes in "bin" 2
    Part 3 dia1 meas .500 and dia2 meas .251 so part goes in "bin" 3
    I cant seem to find any "If/And " type of statement, any suggestions?!?
    Badges..... We don't need no stinkin badges.
    I'm not sure I understand what your sort criteria are. Are they sorted by DIA1 and DIA2 together or independently of each other?
    Craig
      Try something like this:
      ASSIGN/V9 = (PNT4.Z+PNT5.Z+PNT6.Z)/3
                  ASSIGN/V1 = (CIR3.DIAM-CIR3.TDIAM)*-.5
                  ASSIGN/V2 = (CIR3.X-CIR3.TX)*-1
                  ASSIGN/V3 = (CIR3.Y-CIR3.TY)*-1
                  ASSIGN/V4 = (V9-PNT4.TZ)*1
                  ASSIGN/V10 = PNT4.TZ
                  ASSIGN/V5 = IF(ABS(V1)<0.0001,0,V1)
                  ASSIGN/V6 = IF(ABS(V2)<0.0001,0,V2)
                  ASSIGN/V7 = IF(ABS(V3)<0.0001,0,V3)
                  ASSIGN/V8 = IF(ABS(V4)<0.0001,0,V4)
      This ought to help.
      Jan.
        The parts need to be sorted for both dimensions but the 2 dimensions have different criteria.
          So I'm thinking based on the dimensions for each you want to throw up a comment telling the operator what bin to place the part in? Am I following? If that is so, let us know the criteria and we'll see what we come up with.
          Craig
            nested loops
            assign bin=o
            if dia1.d =.500
            if dia2.d = .250
            assign bin=1
            end if
            end if
            if dia1.d =.501
            if dia2.d = .250
            assign bin=2
            end if
            end if
            if dia1.d =.500
            if dia2.d = .251
            assign bin=3
            end if
            end if
            comment, report "Part belongs in bin: " + bin
              Yeah ultimatly we want the comment to pop on the bin number.
              Tray A= Dia 1- .38350-.38385
              Bin 1 in Tray A dia 2- .32530-.32535
              bin 2 in tray A dia 2- .32535-.32565
              bin 3 tray A dia 2- .32565-.32570
              Tray B= Dia 1- .38385-.38415
              Bin 1 in Tray B dia 2- .32530-.32535
              bin 2 in tray B dia 2- .32535-.32565
              bin 3 tray B dia 2- .32565-.32570
              Tray C= Dia 1- .38415-.38420
              Bin 1 in Tray C dia 2- .32530-.32535
              bin 2 in tray C dia 2- .32535-.32565
              bin 3 tray C dia 2- .32565-.32570
              You dont need to tell me how crazy impossible these tolerances are, lol, we just shake our heads when we are asked to do these things.
                DIA1       =FEAT/CIRCLE,RECT,IN,LEAST_SQR
                            THEO/0,0,0,0,0,1,0.3838
                            ACTL/0,0,0,0,0,1,0.3838
                            MEAS/CIRCLE,6,WORKPLANE
                            HIT/BASIC,NORMAL,0.074,0,0,-1,0,0,0.074,0,0,USE THEO = YES
                            HIT/BASIC,NORMAL,0.037,0.0641,0,-0.5,-0.8660254,0,0.037,0.0641,0,USE THEO = YES
                            HIT/BASIC,NORMAL,-0.037,0.0641,0,0.5,-0.8660254,0,-0.037,0.0641,0,USE THEO = YES
                            HIT/BASIC,NORMAL,-0.074,0,0,1,0,0,-0.074,0,0,USE THEO = YES
                            HIT/BASIC,NORMAL,-0.037,-0.0641,0,0.5,0.8660254,0,-0.037,-0.0641,0,USE THEO = YES
                            HIT/BASIC,NORMAL,0.037,-0.0641,0,-0.5,0.8660254,0,0.037,-0.0641,0,USE THEO = YES
                            ENDMEAS/
                            IF/DIA1.DIAM >= 0.3835 AND DIA1.DIAM <= 0.38385
                            ASSIGN/TRAY = "TRAY A"
                            END_IF/
                            IF/DIA1.DIAM > 0.38385 AND DIA1.DIAM <= 0.38415
                            ASSIGN/TRAY = "TRAY B"
                            END_IF/
                            IF/DIA1.DIAM > 0.38415 AND DIA1.DIAM <= 0.3842
                            ASSIGN/TRAY = "TRAY C"
                            END_IF/
                            ELSE/
                            ASSIGN/TRAY = "REJECT"
                            END_ELSE/
                DIA2       =FEAT/CIRCLE,RECT,IN,LEAST_SQR
                            ENDMEAS/
                            IF/DIA2.DIAM >= 0.3253 AND DIA2.DIAM <= 0.32535
                            ASSIGN/BIN = "BIN 1"
                            END_IF/
                            IF/DIA2.DIAM > 0.32535 AND DIA2.DIAM <= 0.32565
                            ASSIGN/BIN = "BIN 2"
                            END_IF/
                            IF/DIA2.DIAM > 0.32565 AND DIA2.DIAM <= 0.3257
                            ASSIGN/BIN = "BIN 3"
                            END_IF/
                            ELSE/
                            ASSIGN/BIN = "REJECT"
                            END_ELSE/
                            IF/TRAY == "REJECT" OR BIN == "REJECT"
                            COMMENT/OPER,NO,"PLACE THIS PART IN THE REJECT BIN"
                            END_IF/
                            ELSE/
                            COMMENT/OPER,NO,"PLACE THIS PART IN " + TRAY + " " + BIN
                            END_ELSE/
                This is how I'd do it but not after explaining that this is utterly and absolutely unreasonable from a tolerance standpoint. You will not be accurate in sorting these with a CMM with these tolerances so this is just a show of code really, as applied it is worthless pratically. Good luck
                Craig
                  That looks like it will do exactly what I want. Thanks!
                  As for the tolerance issue .......well...... anyone, who knows anything, knows better. I guess Engineers and Estimators don't exactly fit that category.
                    BTW you might not want to model your features after mine. I just created two circles wit 6 hits as an example. I have no idea what your part configuration will demand. This of course is aside from the tolerance issue............
                    Craig
                      Yeah, the features aren't really circles n e way. Its actually a sphere rad and a cone crosssection. I just need to get the code written, what "they" do with it is someone elses problem.
                      Maybe when a new pmm-c gets here we can have better luck.
