Dual Monitors
  • Dual Monitors
    Wondering how you setup 3.7MR3 to use dual monitors. Having graphics on one screen and edit screen on the other.
    Thanks!
    Josh
    Scroll to the bottom of the screen and check out the similar threads the forum pulled up for you. HTH
      This is getting easier
        thats so cool... auto search, me likey...
          None of these helped that I could tell. I have the monitors set up and I can go from screen to screen, but, when I try and drag the graphics page over, it won't let me.
            resize pcdmis by dragging to cover both monitors, then you should be able to do what you want.
              No, you shoudn't have to resize PC-DMIS. Try "docking view" of your edit window then grab the edit window and move it to your otherscreen. The edit window is the only one that will move to anothe screen. I have have had my edit window on one screen and the rest of PC-DMIS on the other for about 3.5 years now and have had none of the problems other people have reported about window layouts, screens not staying docked , having to stretch PC-DMIS across 2 screens yada yada yada.
                Where is "docking view" located?
                Bristol Citysigpic
                Home of the Reds
                  Place your cursor in the edit window and right click.
                    I'll try that! Thanks!
                    Right click on the edit window and go down to docking view.
                    Josh
                      James-
                      That worked....There isn't a way to actually dock it over there? There's no maximize option. If I click docking view again, it goes back to the other screen.
                        Create a window layout.
                          more issues
                          After setting up the windows layout, it still doesn't let me dock it on the opposite screen, maybe you can't do it. Anyways, when I start a program, the edit screen moves back on top of the graphics screen. Anyway to fix that?
                          Thanks!
                          Josh
                            Thanks!
                            Josh
                            I don't know if this is what you're looking for, but we'll give it a shot anyway.
                            1. Open program
                            2. Right click in edit window
                            3. check Docking View
                            4. Minimize window
                            5. Drag the window to the upper left display
                            6. Left click on the lower left corner of the window and drag/expand the window onto the right-hand screen. This should give you the edit window on the left and graphics on the right display.
                            Hope that helps some.
                            Just a scooter pilot
                              more docking problems
                              The whole thing was doing good for quite some time. Now, when I open PC-Dmis, the edit screen is laying on top of the graphics screen. Its supposed to be over on the left screen. Even after I click the windows layout icon I created, it still doesn't fix it. When I drag it back over there and put it in the top left corner to resize it, it stretches all the way across both screens and ends up docking to the right screen again.
                              Also, when it was working properly, the edit screen would gradually grow and grow, everytime I executed a program.
                              Now my screens are all JACKED up!
                              Any ideas?
                              Thanks,
                              Josh
