Scan - Feature Set........
  • Scan - Feature Set........
    Can someone explain what I am doing wrong?
    Off-line I created a scan, it is at 0,9,0 with a Ø of 2.8444
    To eliminate outliers I constructed a feature set, now the 'X' is off -.0002 and the diameter is saying it is 1.8898. Am I entering wrong parameters, polar - linear?
    If i report out just the scan, it shows my Ø as measuring .4724.
    Please help!
    SCAN-F- =BASICSCAN/CYLINDER,SHOWHITS=NO,SHOWALLPARAMS=YES
    0,9,0,CutVec=0,-1,0,IN InitVec=1,0,0,DIAM=2.8444,ANG=1440,PITCH=0.225,DEP TH=1,THICKNESS=0,PROBECOMP=YES,AUTO MOVE=NO,DISTANCE=0
    FILTER/NULLFILTER,
    EXEC MODE=FEATURE,USEHSSDAT=YES,USEDELAYPNTS=YES
    BOUNDARY/
    HITTYPE/VECTOR
    NOMS MODE=FINDNOMS,0.0093
    ENDSCAN
    -F- =FEAT/SET,RECT
    THEO/-0.0002,9.5504,0,0,-1,0
    ACTL/-0.0002,9.5504,0,0,-1,0
    CONSTR/SET,FILTER,GAUSSIAN,POLAR,SCAN-F-,
    FILTER/ON,WIDTH=12,UPR=50,OUTLIER_REMOVAL/ON,3
    DIM LOCATION2= LOCATION OF SET -F- UNITS=IN ,$
    X -0.0002 0.0010 0.0010 -0.0002 0.0000 0.0000 ----#----
    Z 0.0000 0.0010 0.0010 0.0000 0.0000 0.0000 ----#----
    D 1.8898 0.0010 0.0010 1.8898 0.0000 0.0000 ----#----
    END OF DIMENSION LOCATION2
    DIM LOCATION1= LOCATION OF SET SCAN-F- UNITS=IN ,$
    X 0.0000 0.0010 0.0010 0.0000 0.0000 0.0000 ----#----
    Z 0.0000 0.0010 0.0010 0.5000 0.5000 0.4990 -------->
    D 2.8444 0.0010 0.0010 0.4724 -2.3720 2.3710 <--------
    END OF DIMENSION LOCATION1
    I also constructed cyl from the scan-F-, It reports out great, the only thing is that the outliers will cause this to show bad when ran on-line. So I created one from the feature set -F- and, well as you can see, it is no where close to nominal.
    CYLIN1 =FEAT/CYLINDER,RECT,IN,MAX_INSC
    THEO/0,9.5504,0,0,-1,0,2.8444,0.8991
    ACTL/0,9.5504,0,0,-1,0,2.8444,0.8991
    CONSTR/CYLINDER,BF,SCAN-F-,,
    DIM LOCATION3= LOCATION OF CYLINDER CYLIN1 UNITS=IN ,$
    D 2.8444 0.0010 0.0010 2.8444 0.0000 0.0000 ----#----
    END OF DIMENSION LOCATION3
    CYLIN2 =FEAT/CYLINDER,RECT,IN,MAX_INSC
    THEO/-0.2673,8.3284,0.1919,0.7182016,-0.0470142,0.694245,2.2751,2.4063
    ACTL/-0.2673,8.3284,0.1919,0.7181996,-0.0470143,0.6942471,2.2751,2.4063
    CONSTR/CYLINDER,BFRE,-F-,,
    DIM LOCATION4= LOCATION OF CYLINDER CYLIN2 UNITS=IN ,$
    X -0.2673 0.0010 0.0010 -0.2673 0.0000 0.0000 ----#----
    Z 0.1919 0.0010 0.0010 0.1919 0.0000 0.0000 ----#----
    D 2.2751 0.0010 0.0010 2.2751 0.0000 0.0000 ----#----
    END OF DIMENSION LOCATION4
    PCDMIS 4.1, 3.5mr2,
