Profile of a Surface
  • Profile of a Surface
    Having problems tolerancing profile of a surface
    Using 2009 MR1
    Tolerancing with Xactmeasure
    See attachment to see callout (dim 5)
    I measure two cylinders (one for each Radius R10 & R15)
    I get a couple of problems during tolerancing.
    1. When I try to apply the modifier to Datum C, the software tells me "encountered an improper argument" (Do I not get bonus on this Datum because of the Bonus of Datum B)
    2. When I disregard the MMC on Datum C, I select both cylinders and it forms a feature set, however, i only get two points for my text analysis, and it is reporting the deviation of my Z axis deviation.
    Datum A on the CMM is Z+
    Profile does not allow bonus.
      PC-DMIS is correct. You can not have a virtual condition on datums (the MMC behind the B and C) if you call for surface profile. See the standard. What is datum B???
        It is reporting the cylinders from their respective center. 2 cylinders, 2 points. Either use a scan or vector points and create a feature set.
          I thought the modifier wasn't allowed on the feature itself, but allowable on the Datums. This would be applicable for a Datum shift... I sought out the standard and if i read it correctly, i thought it says i could (on at least Datum B).
          Datum B is the other through hole. Sorry i cut that out by accident.
            Using 2009 MR1
            [ATTACH=CONFIG]6676[/ATTACH]
            Additionally, the Profile refers to the entire surface, and not just the radiused ends. Scan or create vector points all around, create a Feature Set from the collected points, and Profile the set.
              Very true... I forgot to mention that this outside surface is extruded and thus, if my feature set from the two radii are in specification, so will the sides since they are merged from the two ends.
                Yes it does. I believe it is in the 2009 revision
                See above comment
                You are correct
                That is incorrect. just because the two radius make up either end has no bearing on how the sides have been created. If I am wrong tell me so.
