Alignment??
  • Alignment??
    Hey guys, I have complete my first new program, as I try testing out the first pc online, Im already having all sorts of problems in the beginning, i set a rd point to start at a hole after it does that the probe does not seem to find the part at all, but now I'm getting a machine parameter out of tol. Im not to sure what it is im doing wrong.. below I have posted my alignment..65B17805-3 - B_draft_4_11_11_outoftol.pdf
    STARTUP =ALIGNMENT/START,RECALL:, LIST= YES
    ALIGNMENT/END
    COMMENT/REPT,******************************33464 RQ*****************************
    MODE/MANUAL
    MOVESPEED/ 40
    TOUCHSPEED/ 1.2
    LOADPROBE/PORT1
    TRACEFIELD/DISPLAY,LIMIT=15 ; JOB NO. :
    COMMENT/OPER,NO,PLACE PROBE ON LEFT .500 HOLE
    RD PNT =FEAT/POINT,RECT
    THEO/0,0,0,0,0,1
    ACTL/9.3064,23.5613,-23.2416,0,0,1
    READPOINT/
    A0 =ALIGNMENT/START,RECALL:STARTUP, LIST= YES
    ALIGNMENT/TRANS,XAXIS,
    ALIGNMENT/TRANS,YAXIS,
    ALIGNMENT/TRANS,ZAXIS,
    ALIGNMENT/ROTATE_OFFSET,40.684,ABOUT,XPLUS
    ALIGNMENT/TRANS_OFFSET,YAXIS,3.0006
    ALIGNMENT/END
    MODE/DCC
    MOVE/POINT,NORMAL,9.9737,4.0183,5.934
    TIP/T1A90B90, SHANKIJK=-1, 0, 0, ANGLE=130.684
    PT10 =AUTO/VECTOR POINT,SHOWALLPARAMS = YES
    THEO/-0.37,-4.7159,4.7477,-1,0,0
    ACTL/9.5062,0.6176,5.1584,-1,0,0
    TARG/-0.37,-4.7159,4.7477,-1,0,0
    THEO_THICKNESS = 0,RECT,SNAP = YES,$
    AUTO MOVE = BOTH,DISTANCE = 1
    PT11 =AUTO/VECTOR POINT,SHOWALLPARAMS = YES
    THEO/-0.37,-6.975,4.1319,-1,0,0
    ACTL/-1.3195,-5.1954,33.8657,-0.3296309,-0.1152658,0.9370471
    TARG/-0.37,-6.975,4.1319,-1,0,0
    PT12 =AUTO/VECTOR POINT,SHOWALLPARAMS = YES
    THEO/-0.37,-9.9659,5.1045,-1,0,0
    ACTL/-0.7891,-8.3399,35.006,-0.3296309,-0.1152658,0.9370471
    TARG/-0.37,-9.9659,5.1045,-1,0,0
    PT13 =AUTO/VECTOR POINT,SHOWALLPARAMS = YES
    THEO/-0.37,-12.4034,4.3437,-1,0,0
    ACTL/-1.3436,-10.6866,34.0613,-0.3296309,-0.1152658,0.9370471
    TARG/-0.37,-12.4034,4.3437,-1,0,0
    MOVE/INCREMENT,0,0.0836,6
    TIP/T1A0B0, SHANKIJK=0, 0.6519, 0.7583, ANGLE=0
    PRE ITER .500 CIR2 =AUTO/CIRCLE,SHOWALLPARAMS = YES,SHOWHITS = NO
    THEO/-1.38,-5.3767,0.5806,0,0.0119377,0.9999287,0.5
    ACTL/-2.1094,-3.1888,30.4981,0,0.0119377,0.9999287,0.5
    TARG/-1.38,-5.3767,0.5806,0,0.0119377,0.9999287
    THEO_THICKNESS = 0,RECT,IN,STRAIGHT,LEAST_SQR,ONERROR = NO,$
    AUTO MOVE = BOTH,DISTANCE = 1,RMEAS = None,None,None,$
    READ POS = NO,FIND HOLE = NO,REMEASURE = NO,$
    NUMHITS = 8,INIT = 3,PERM = 3,SPACER = 0.15,PITCH = 0,$
    START ANG = 0,END ANG = 0,DEPTH = 0.1,$
    ANGLE VEC = -1,0,0
    MOVE/INCREMENT,0,0.0836,6.9995
    PRE ITER .500 CIR3 =AUTO/CIRCLE,SHOWALLPARAMS = YES,SHOWHITS = NO
    THEO/0.82,-5.3767,0.7429,0,0.0119377,0.9999287,0.5
    ACTL/0.0906,-3.1888,30.6604,0,0.0119377,0.9999287,0.5
    TARG/0.82,-5.3767,0.7429,0,0.0119377,0.9999287
    ANGLE VEC = -1,0,0
    PRE ITER =ALIGNMENT/START,RECALL:A0, LIST= YES
    ALIGNMENT/ITERATE
    PNT TARGET RAD = 0.05, START LABEL = , FIXTURE TOL = 0, ERROR LABEL =
    MEAS ALL FEAT = ONCE ,MAX ITERATIONS = 5 ,LEVEL AXIS=ZAXIS ,ROTATE AXIS=YAXIS ,ORIGIN AXIS=XAXIS
    LEVEL = PT10,PT11,PT12,PT13,,
    ROTATE = PRE ITER .500 CIR2,PRE ITER .500 CIR3,,
    ORIGIN = PRE ITER .500 CIR3,,
    ALIGNMENT/END
    MODE/DCC
    MOVE/INCREMENT,-0.0001,0.0836,6.9995
    ACTL/-11.0465,-3.1412,34.4748,-1,0,0
    ACTL/-11.0465,-5.4003,33.859,-1,0,0
    ACTL/-11.0465,-8.3912,34.8316,-1,0,0.0000214
    ACTL/-11.0465,-10.8287,34.0708,-1,0,0.0000214
    MOVE/INCREMENT,0,0,6
    FIN ITER .500 CIR2 =AUTO/CIRCLE,SHOWALLPARAMS = YES,SHOWHITS = NO
    ACTL/-12.0564,-3.802,30.3077,-0.0000109,0.0119377,0.9999287,0.5
    ANGLE VEC = -1,0,0
    FIN ITER .500 CIR3 =AUTO/CIRCLE,SHOWALLPARAMS = YES,SHOWHITS = NO
    ACTL/-9.8564,-3.802,30.4701,-0.0000018,0.0119377,0.9999287,0.5
    ANGLE VEC = -1,0,0
    FIN ITER =ALIGNMENT/START,RECALL:PRE ITER, LIST= YES
    ALIGNMENT/ITERATE
    MEAS ALL FEAT = ALWAYS ,MAX ITERATIONS = 5 ,LEVEL AXIS=ZAXIS ,ROTATE AXIS=YAXIS ,ORIGIN AXIS=XAXIS
    ROTATE = FIN ITER .500 CIR2,FIN ITER .500 CIR3,,
    ORIGIN = FIN ITER .500 CIR3,,
    ALIGNMENT/
    END
    Can't access your pdf....
    Lately, it occurs to me
    2017 R1 (Offline programming)
      Yeah...same here:
      DungT, you do not have permission to access this page. This could be due to one of several reasons:
      Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
      If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation.
        ok since it wasnt able to be opened i pasted the alignment..
          Originally posted by macosta View Post
          Hey guys, I have complete my first new program, as I try testing out the first pc online, Im already having all sorts of problems in the beginning, i set a rd point to start at a hole after it does that the probe does not seem to find the part at all, but now I'm getting a machine parameter out of tol. Im not to sure what it is im doing wrong.. below I have posted my alignment..[ATTACH]6622[/ATTACH]
          ALIGNMENT/END
          MODE/MANUAL
          MOVESPEED/ 40
          TOUCHSPEED/ 1.2
          LOADPROBE/PORT1
          THEO/0,0,0,0,0,1
          READPOINT/
          ALIGNMENT/END
          This section
          ALIGNMENT/END
          MODE/MANUAL
          MOVESPEED/ 40
          TOUCHSPEED/ 1.2
          LOADPROBE/PORT1
          THEO/0,0,0,0,0,1
          READPOINT/
          ALIGNMENT/END
          I didn't look any further since this will cause the problem you are having "the probe does not seem to find the part at all".
          You are recalling the original machine alignment (STARTUP) and not using the Read Point in the first "part" alignment. Matter of fact, you are not referencing anything for XY and Z origins.
            …Too much explaining to do. The quickest way to solve your problem is to post a partial drawing; may be someone here nice enough to write a sample code for you to look at.
              If Matt was here I bet he could help
                We have a wiener right there. The alignment does diddlysquat.
                Ira gets the prize.
                Further review shows your second alignment is the same way.
                Looks like you didn't click on the features that you wanted to use for your alignment.
                Despite what a salesperson might have said, the software doesn't program for you....
                Originally posted by ir a programmer View Post
                This section
                ALIGNMENT/END
                MODE/MANUAL
                MOVESPEED/ 40
                TOUCHSPEED/ 1.2
                LOADPROBE/PORT1
                THEO/0,0,0,0,0,1
                READPOINT/
                ALIGNMENT/END
                  Don't use spaces, or math symbols when naming a feature.
                  Alpha characters, numbers, underscore key. This is what the manual recommends.
                  When creating an alignment, you have to select a feature from the side box. Ortherwise you get a meaningless alignment.
                    Macosta,
                    I have to ask, have you had training?
                    It is stated over and over here, but training is KEY.
                    This stuff does not happen on it's own.
                    John "Arrogant [email protected]" Kingston
                      ...or vpt.se
                      im gonna miss you bob....
                        Originally posted by ruidoso View Post
                        ...or vpt.se
                        This is true but at the time I posted vpt.se was still in good standing. Watch it you could be next. Back across the border with you
                          If by good standing you mean had ALL his posts deleted but was still alive, then yes.
                            Your not using the read point as origin on the first aln...
                            PC-DMIS CAD++ 2013
                            Brown & Sharpe global performance
                              Agree with all, you need to select "read point" from the feature box, in the alignment utilities window, before checking "x" "y" & "z" and establishing an origin for them.
                              Hasta la victoria, siempre.
