Red lines, big honkin red arrows
  • Red lines, big honkin red arrows
    I got em, what are they?
    Stalactites?
      Point deviation graphics? Turn 'em off. Reduce multiplier.
      TK
      sigpicHave a homebrew
        Just to clarify Tkings answer if you haven't found the way to turn off the arrows. Click on the dimension line in your report for the features (points) that you checked. Right click then go to edit, then in the lower right hand corner un check Graphical display or reduce the multiplier. Depending on which you do the arrows will get smaller or disappear.
        Tolerance challenged ... Living in the world of unseen lines.
          Roman, It could be that you have manually (accidently?) taken some hits, too. Try hitting "End" and then erase the feature it created.
          BeckyK
          Sheffield, B&S
          (1)1808-M, (4)D-28, (1)RS-70, (3)RS-150, (1)Mxcel PFX
          PC-Dmis 2009 MR1, 2013 MR1
            Thanks Lee, I was kinda busy actually.
            TK
              You should also check your nominal values on dimensions you are reporting, sometimes when editing they get messed up.
              Hasta la victoria, siempre.
                Thanks for all the input. I can't get rid of em yet, however it is not my program and I disagree with the alignment/datums used. Using simulated surfaces/datums and calling them one plane even thought the are different surfaces.Trying to cheat just to get it take the alignment.It's all askew.
                  Found It! It was the deviations arrow multiplierin SETUP (F%), thanks for all the help
                    Wow..... answered way back in posts 3 and 4.......
                    TK
