I'm running 3.5 and I have taken a large number of features and points (point clouds) on a part that we are trying to reverse engineer. How do I export these points to a "CAD" file so it can be imported into Catia for further design work.
Exporting point clouds to CAD
The easiest way is probably:
FILE/EXPORT/IGES
Setup the points you want to export and what coordinate system to use then process and run.
(follow the help file directions if you hit a problem it is explained in there what to do)
Then import the iges file into catia.
Just remember you can only output measured data and not constructed features.Roses are red
Violets are glorious
Don't try to sneak up
On Oscar Pistorius.
MIL-TFP-41C
3.7mr3, 2012mr1, 2013mr1
I occasionally export data to be used to 'build' a CAD model based on the data. Experience has shown me to use individual hits, rather than AutoFeatures, especially things like AutoPlanes which are represented by a triangle because the extent of the plane is not apparent from a small triangle. AutoCircles are cool, but don't show roundness of that circle --- they very clearly show location and (average) size of the feature, though.
Like others, I export the data as an IGES file, after making and selecting the desired alignment. I then IMPORT the IGES file into NX (rather than trying to 'OPEN' the IGES file)
by W0QNXThey want to "prove out" the conversion process between me importing an IGES made in Catia and what PCDMIS makes.
I can't get...-
10-08-2009, 02:18 PM -
by CTD2003Hello all,
So im trying to implement an automatic export of iges files if our parts are found to be nonconforming. i made a point cloud using "insert-Pointcloud-Feature",....-
04-13-2022, 02:45 PM -
How do I export a point cloud (Using CAD) to SolidWorks so that the point I take are visible? Everything I've tried just shows up as a triangle??
12-02-2015, 03:33 PM -
I did a scan for our engineering department 2 months ago to get some dimensions on a new part, today they asked me if I could export the pointcloud for...
Channel: PC-DMIS Portable
07-01-2020, 05:51 PM -
by cappy6124Hi everybody out there in CMM Land!
Does anyone have a script to export your data to an IGES file?
or would it just be easier to...-
Channel: PC-DMIS Code Samples
04-09-2012, 11:04 AM -
