New to the Forum we were thinking of purchasing an Artifact to verify that our CMM's are still within calibration. Has anyone had experience using one could you share your thoughts.
Usage of Artifact to verify CMM
Search for threads on calibration that Hilton Roberts has posted in. He is a Guru in calibration and tracking how your machine is performing. His first question to you will be, "Do you have a "master part" that you measure every day?
Here is one of the links.
http://www.pcdmisforum.com/showthrea...hilton+robertssigpicIt's corona time!
We have created an artifact for doing exactly what you mention.
We machined the part (basically a circle_diamond_square with some contoured surfaces and holes) and then had it anodized and measured/certified by a lab.
I then wrote a PC-DMIS program duplicating the XYZ_IJK values from the lab report.
Our machines are able to duplicate the lab's results within .0003".
I was happy with this.
We also saw correlation between our 3 CMMs within a similar variation.
We run the artifact program whenever we have a machine calibration or repair and just anytime we want to verify that things are still "OK".
It does not replace the need for calibration, but it does give you confidence that the machine is performing as expected.
I only wish the artifact were bigger (we have LARGE CMMs).Lately, it occurs to me
2017 R1 (Offline programming)
We are currently using an "Artifact" which is one of the original Hexagon aluminum test blocks measured and qualified by Hexagon and includes a simple program (writtem in 3.5 and edited for use in PCDMIS2010MR2) to periodically (every 3 months) and annually run to document any changes in our DCC CMM Product Assurance Software and individual machine measurement capabilities in order to meet the Boeing Digital Product Definition and Model Based Definition requirements.
It was not cheap. However, it was cheaper than purchasing a Ball Bar set-up which may require a 3rd party annual calibration.
Contact your Hexagon sales rep and/or Technical Support for further info.
Good luck!Lead DCC CMM Programmer
B & B Manufacturing
Valencia, CA
PCDMIS 2010 MR1 CATIAV5R19 DCI/DCT
5 Brown & Sharpe Global/Image/Advantage DCC CMMs
Here is the Artifact we are thinking of purchasingAttached Files
We have and use one very similar to the one shown. Helps to dispell those pesky manufacturing types that doubt you CMM's repeatability. Check on a monthy basis or after a Bonobo ape crash.sigpic
I am fluent in three languages:
English, Sarcasm & Profanity.
Braz60, check this one too. It's about what programmers use to verify their CMM accuracy.
I just take one of our most complex parts and run it thru a few times and save the results.
Then anytime anyone doubts the readings that we get I can rerun the part and compare the results .
Works good forafter crashes and for when operators really screw up coordinate on a machining centers.
Beeer ThirtyCookie
by terryWe are researching different ways of verifying the calibration of our CMM’s between calibration cycles. The powers at be do not seem think it is necessary...Ball Bar18.92%7Renishaw machine checking gage24.32%9Koba Step gage13.51%5Dont Verify43.24%16
07-19-2006, 08:20 PM -
by sharneyWe have our CMM calibrated every three years and I was just wondering what others are doing. So far we do not have any customers demanding a more frequent...
05-27-2014, 03:28 PM -
by rlafayOk got a question here.
I have a newly qualified CMM from Hexagon, an Excel in fact, and am thinking about the qualification procedure.
08-09-2008, 11:14 AM -
by bpenningsDoes anyone know where I could find a somewhat detailed description of the tasks performed during an annual CMM calibration? Some individuals believe...
01-30-2007, 07:11 PM -
by giantslayerThe company I am now working for does not have a service contract with Hexagon and has been having RMS a third party company come in and do the calibration....
07-30-2015, 06:01 PM -
