Good morning everyone. A non-PCDMIS question for a change. Our company is moving one of our CMM's onto the shop floor and building a nice little room around it for an inprocess inspection lab. My boss has questions as she's redoing our budget for this project. What type (make, model, manufacturer, etc.) of iso vibration padding should we employ about the feet to keep the vibration down and what does that usually run cost wise? Now I'm not sure on how they (Our loving company maintence team) are going to do this whether they do the whole floor (which I doubt becuase it costs more then 3 dollars or just individual pads for the CMM supports on a concrete base. The machine is a large Sheffield. Any input would be an asset. Thanx.
CMM Vibration
Originally posted by Matthew D. Hoedeman View PostI have a Barry system. Not sure about the $, it's been here longer than me. It's a vibration isolation system as well as a leveling system, uses 6 air cans under the machine.
Raven...MAKE SURE YOUT MAINTENANCE MONKEYS REATTACH THE TRANSPORTATION BRACKETS BEFORE MOVING THE CMM
Our CMM is fairly close to he press department. The MMs here busted up the floor, before I got here so I don't know how deep, and poured, or tried to pour, an isolation pad for the machine to sit on. I still get slight vibrations if our bigg press is really hammering something heavy.Perry
B&S Mistral
3.207 Beta on XP
Older'n dirt
That's great that they're doing something for you. There are quite a few companies out there offering pads. If you want to do it right, you should do a study on the actual frequency of the vibrations you are getting on a day-to-day basis, so you can target the pad type to that specific range.
My CMM has a large press not 20 feet away. When doing a large scan (500+ points) with my touch trigger probe while they're running a job, the probe inevitably takes a point at the same time they blank a part, and the machine gets confused and drives the probe into whatever I'm inspecting. I come back and my TP-200 module is lying on the table with a broken tip. WTF!
Chally, thats just plain funny not!
Our B&S global base sits in the QA lab but on the same floor as our big stamping presses although the big presses are almost 100 yards away. The cmm base sits on it metal feet. The granite is on 3 riser pins each on 1/2" plastic delrin pads on top of 1/2" rubber isolation pads. I can barely feel the hits from the big machine when we're running really thick material through it. AND, there are train tracks <50' from the cmm.
One day, as a train was going past, my boss walked over and asked why I stopped the layout on the cmm before the program was done. I went Jurassic Park on him... I said "because of this" as I put my coffee on the cmm. He looked puzzled. I told him to put his hand on the cmm and look at the waves in the coffee. He asked if this would affect the dimensions. I just smiled and said "do you want to take that chance?" Then I secured a gauge block on the stage, put the probe almost touching it and we watched it shake enough to hit the gauge block.Last edited by Slug Dawson; 10-22-2010, 03:46 PM.To some the glass is half full
To some it is half empty
To me it is poorly designed by the Eng & Prod wants me to find a way to measure it in spec!
- 1 like
As with all CMM's when you move them into a shop enviroment you deal with the two main issues or problems. Vibration and contamination. These machines that were originally designed for a lab environment don't take well to vaporous coolant flying about and landing on the scales (thus the addition of the climate controlled room) and the wonderful occurances to a TP200 when a large press or giant mill cutting armor plate rattles the kohoonies right off your lower extremities. I'll try and contact Barry systems and see what they suggest and cost. Also, Perry, a year ago, they (the MM's) tried moving one of our CMM's in one of our other buildings without using the transport brackets and ended up calling in B&S to realign the bridge after it kiltered during the transport. DUMB!Physics dictates to man why his world acts the way it does....Chemistry tells him why it smells the way it does.
Originally posted by Slug Dawson View PostDo they still make those isolation pads out of the entrails of Design Engineers who don't understand GD&T?
Born of experience huh?Actively looking to be a CMM guy again
Previously 4.3 MR2
XP OS
Is your problem a case of operator headspace?
(Which is not such a bad thing i think)Roses are red
Violets are glorious
Don't try to sneak up
On Oscar Pistorius.
MIL-TFP-41C
3.7mr3, 2012mr1, 2013mr1
my company bought a new cmm and put it on the shop floor next to cnc machines and swiss machines. they put a room around it but did nothing for vibrations. also noticed that the whole cmm machine moves and shakes and also does this while taking hits on the parts. told this was normal.
- 1 like
by MFCguyOur building was set up with our quality lab right next to 3 of our blanking presses. It is vibrating the **** out of the floor. I finally got the go...
05-15-2007, 11:45 AM -
by djayneHey guys -
I need some advice. I have the budget to buy a new lab CMM and a new shop floor CMM. I was hoping to keep everything uniform and...-
05-26-2006, 04:25 PM -
by John RigginsI have been tasked with researching how to ameliorate the vibration impact to a CMM installation.
We are thinking of moving one of our large...-
01-06-2012, 05:25 PM -
by 2girlieLike my title?
Anyhow, every time the 50,000 tonne crane goes by (2 to 3 passes an hour) my cmm skips about - so no it is not on a separate...-
04-04-2008, 12:32 PM -
by DeWain HodgeI'm looking for opinions here. What do the people that have the B&S ONE shop floor cmm's think of them. We are looking at the purchase of an additional...
05-30-2008, 11:38 AM -
