Offline Alignment and Programming
  • Offline Alignment and Programming
    Hello all,
    We are using PCDmis 2010 MR2, and I have a few questions about programming offline with a CAD model.
    1. After I hit my alignment points in CAD, and then hit them on the machine and align the two, can I then just save the alignment and recall it at the beginning of the program? Thereby avoiding having to manualy touch the points again to align the part? (Considering I am using a fuxture to hold the part and a locator plate to place it in the same position on the surface plate again and again.)
    2. After the whole problem in question number 1 is solved, can I then just put all my dimensions in online, on the CAD model using auto features? The whole plan is to program as much as possible offline and have a program ready before a physical part comes off the machine. I realize I may have to at least hit the alignment points on the part still, but that is an issue we wil deal with if/when it happens. Until then, do I just click my features on the CAD model using auto, or measure?
    Many, many thanks in advance for any and all advice!
    Quality Engineer - Connecticut
    Browne & Sharpe Global (X4)
    CAD ++ 2010 MR2 Build #78
    15+ Years CMM Programming
    1. You need to have two alignments written offline. A manual followed by an auto. Once you get your part in, run BOTH alignments. After you measure the manual alignment the first time, mark that section off by highlighting then pressing F3 and save your program. You should really never have to do this manual alignment again after that, considering you have the part placed in the same position everytime.
    2. Yes. You can then create all of your features on your CAD model using auto features.
    2010 MR2 -- Global B&S -- D28 (3) -- 1805 -- DCC 1808
      And make sure you translate your CAD coordinate system to the way you are going to have it on your machine. AND DON'T USE CAD=PART.
        Originally posted by JStewart View Post
        Hello all,
        1: Yes
        2: You can put your dims in offline as well why wait to go online?
        Use autofeatures as it is easier.
        Roses are red
        Violets are glorious
        Don't try to sneak up
        On Oscar Pistorius.
        MIL-TFP-41C
        3.7mr3, 2012mr1, 2013mr1
          Why?
          Some people do and some dont.
          Opinion is divided on the issue.
          Roses are red
          On Oscar Pistorius.
          MIL-TFP-41C
            Great advice! Thanks to all for the input. I have a great Engineering team that aligns the CAD model origins to whatever I need them to be before they send me the iges file, so no worries there. Other than that, I find it easier on the mind to do an iterative alignment rather than sort through cad=part.
            Again, many thanks to all.
              You are lucky to have such a cooperative group. It might not always be that way.
              If you have time you should learn what to do if the CAD is not aligned as per your setup.
              This is quite easy once you learn it, but learning it is quite a PITA.
              Lately, it occurs to me
              2017 R1 (Offline programming)
                Did you download the new, fixed version of MR2, by the way? The original release had some serious problems with autofeatures.
                  Without seeing a BP, watch your clearance moves to next feature to be measured when programming offline. Are you familiar with "clearplane" ?
                  I am fluent in three languages:
                  English, Sarcasm & Profanity.
                    "I have a great Engineering team that aligns the CAD model origins to whatever I need them to be before they send me the iges file, so no worries there."
                    What... and only 2 posts, sounds like a troll. Engineering team that is helpful indeed!
                    Shouldn't you be getting ready for the SX season?
                    To some the glass is half full
                    To some it is half empty
                    To me it is poorly designed by the Eng & Prod wants me to find a way to measure it in spec!
                      I am currently using: PC-DMIS CAD++ Version 2010 MR2 Aug 26 2010 build. Hopefully that is the latest, if not then looks like I need to bother the IT guys again!
                      Trust me, I was just as shocked as you are, but they are actually quite helpful!
                        Get ready to bother them, amigo. The "fixed" version (if you can believe it) is build #78.......dated Oct 5. Me? I'm gonna skip MR2 and wait for MR3, 'cause I like my bugs fresh.
                          Build #78?!?!?! Ouch. We literally just downloaded and installed the "latest" build last week due to all the machines being at 2009 MR1 when I got here! Oh well, time to call IT. Thanks for the heads up.
                            Better call tech support too.
                              Good on you for doing an iterative alignment using autofeatures, this is the easiest way to work offline.
                              +1 to doing 2 alignments, thats the easy way also.
                              Jim Jewell
