Hello all, I'm looking for an explanation of the advantage of using external code in your program.
Alignments: I've heard others here talk about saving alignments as external alignments and then recalling them into the program and don't understand the advantages of doing this. Most of our programs start with a manual alignment or a single point aligned as XYZ-0.
Features: Is there any advantage to having feature sets as external code to use for similar parts?
Dimensioning: Any advantage to having the dimensioning as extrenal code and then recalling it for parts checked through different stages of production as stated in my example below?
The reason I'm asking is because we have a part that gets stamped & needs inspected at that point. Then it gets formed & needs inspected at that point. Lastly, it gets inserts put into it and it needs final layout as finished goods.
Would I set this up as 3 programs, one for each stage & just pull in the code for the necessary steps for each stage?
What is the advantage us using external code over copy/paste into another program?
Thanks for your input.
