Reported angle
  • Reported angle
    How can I get PCD to report an 327° angle instead of -33°?
    DeWain Hodge
    Well, there are things to try (but you haven't given us much to go on)
    1) Try reversing one (or both) of the lines you are trying to get the angle of
    2) Check the setting for angle reporting, change it from +/-180 to 360 (F5, dimension tab)
      In versions prior to 4.x the answer was often, you can't. What I used to do instead was put a comment in the report just before the dim : "360-327=33"
      However in the 4head versions I have used it has always been possible to get the exact angle I want into the report.
      As Matt said, make sure you are set for 360 rather than +/-180.
      Correct workplane is also necessary for 2D angles.
      Type the nominal into angle dimension window. Many times I have clicked Ok or Done in the angle window then see that it spit out 33 instead of 327, F9 to reopen, type 327 into the nominal box and then my report has 327.
      The other caveat here is that if you are trying to report the angle between a feature and an axis it might not work. A couple of times I have had to change from angle to axis to angle to feature in order to get the number I need in the report.
      HTH
        What they said.
        In addition, sometimes I construct "reverse" lines to get the right angle.
        sigpicIt's corona time!
          surprised nobody above said to use an assignment and force the dimension to be what you want....
          Starrett RGDC 4028-24 :alien:
            Different cases :
            Angle between 2 features :
            ASSIGN\ANGLE_1=ANGLEBETWEEN(FEAT1.IJK,FEAT2.IJK)
            Angle between a feature and an axis :
            ASSIGN\ANGLE_1=ANGLEBETWEEN(FEAT1.IJK,ALIGN1.XAXIS )
            Angle between 2 constructed vectors :
            ASSIGN\ANGLE_1=ANGLEBETWEEN((PT1.XYZ-PT2.XYZ),(PT3.XYZ-PT4.XYZ))
            You can mix these various cases, or create others !
              I always just changed the nominal in the report for the desired angle. When you run the program the correct angle will be reported!
              Sent from my iPhone using Tapatalk
              Southern Man don't need him around anyhow!
              • mdobb829
                Reported Angle
                by mdobb829
                Can anyone tell me how I can force a reported ANGLE to the angle call out on the print? I have a 15° angle call out on the print. When I ask for the...
                08-01-2008, 04:01 PM
              • Curty_82
                new way angle calculates in 2009MR1
                by Curty_82
                Hello, I just went from 3.7 to 2009 MR1 and it wont let me do the complement angle any more.. How do I get pc dmis to report the old way so I can get...
                04-23-2010, 12:14 PM
              • seppley
                Angle Dimension Probs....
                by seppley
                Hi all,
                I have a 2 fold question/problem and I believe they are connected.
                #1 When I create an angle dim. in the creation...
                11-14-2012, 10:31 AM
              • keego
                Angle to YAXIS
                by keego
                I need to find the angle of a feature to my YAXIS. How do I?
                In MM4 you can select an axis as a feature, but I don't see that in PC-Dm...
                03-18-2009, 08:58 AM
              • Londonjr
                Inclusive angle
                by Londonjr
                How would I determine an inclusive angle? I am measuring a cone with a very minimal plane at the top of the part. (Maybe .002 land) 100 deg +/- 1 deg...
                03-23-2016, 10:37 AM
