What is the preferred way to post PCDMIS code when asking for help? I tried a copy/paste into wordpad and then into the forum, but it looks like crap. Thanks.
PCDMIS 2009
Sheffield Discovery
PCDMIS 2009
Sheffield Discovery
COMMENT/OPER,NO,3 points on the top surface PNT1 =AUTO/VECTOR POINT,SHOWALLPARAMS = YES THEO/1611.5379,-810.278,220.8039,0.0508008,0.1213018,0.9913149 ACTL/-1611.5379,810.278,220.8039,-0.0508008,-0.1213018,0.9913149 TARG/1611.5379,-810.278,220.8039,0.0508008,0.1213018,0.9913149 THEO_THICKNESS = 0,RECT,SNAP = NO,$ AUTO MOVE = NO,DISTANCE = 0,$ FIND NOM AXIS = NONE,UPDATE VEC = 0.0508008,0.1213018,0.9913149,$ REPORT VEC = 0.0508008,0.1213018,0.9913149 PNT2 =AUTO/VECTOR POINT,SHOWALLPARAMS = YES THEO/1622.8502,-809.0151,220.0694,0.0508008,0.1213018,0.9913149 ACTL/-1622.8502,809.0151,220.0694,-0.0508008,-0.1213018,0.9913149 TARG/1622.8502,-809.0151,220.0694,0.0508008,0.1213018,0.9913149 THEO_THICKNESS = 0,RECT,SNAP = NO,$ AUTO MOVE = NO,DISTANCE = 0,$ FIND NOM AXIS = NONE,UPDATE VEC = 0.0508008,0.1213018,0.9913149,$ REPORT VEC = 0.0508008,0.1213018,0.9913149 PNT3 =AUTO/VECTOR POINT,SHOWALLPARAMS = YES THEO/1623.2163,-812.7802,220.5114,0.0508008,0.1213018,0.9913149 ACTL/-1623.2163,812.7802,220.5114,-0.0508008,-0.1213018,0.9913149 TARG/1623.2163,-812.7802,220.5114,0.0508008,0.1213018,0.9913149 THEO_THICKNESS = 0,RECT,SNAP = NO,$ AUTO MOVE = NO,DISTANCE = 0,$ FIND NOM AXIS = NONE,UPDATE VEC = 0.0508008,0.1213018,0.9913149,$ REPORT VEC = 0.0508008,0.1213018,0.9913149 PLN1 =FEAT/PLANE,RECT,TRIANGLE THEO/1619.2015,-810.6911,220.4616,0.0508216,0.1213157,0.9913121 ACTL/-1619.2015,810.6911,220.4616,-0.0508216,-0.1213157,0.9913121 CONSTR/PLANE,BF,PNT1,PNT2,PNT3,, OUTLIER_REMOVAL/OFF,3 FILTER/OFF,WAVELENGTH=0 A0 =ALIGNMENT/START,RECALL:STARTUP, LIST= YES ALIGNMENT/LEVEL,ZPLUS,PLN1 ALIGNMENT/TRANS,XAXIS,PLN1 ALIGNMENT/TRANS,YAXIS,PLN1 ALIGNMENT/TRANS,ZAXIS,PLN1 ALIGNMENT/END COMMENT/OPER,NO,2 points on the near end, left first. PNT4 =AUTO/VECTOR POINT,SHOWALLPARAMS = YES THEO/26.7816,-5.0284,-0.0228,0.9998307,-0.0184006,0 ACTL/26.7816,-5.0284,-0.0228,0.9998307,-0.0184006,0 TARG/26.7816,-5.0284,-0.0228,0.9998307,-0.0184006,0 THEO_THICKNESS = 0,RECT,SNAP = NO,$ AUTO MOVE = NO,DISTANCE = 0,$ FIND NOM AXIS = NONE,UPDATE VEC = 0.0184006,0.9998307,0,$ REPORT VEC = 0.0184006,0.9998307,0 PNT5 =AUTO/VECTOR POINT,SHOWALLPARAMS = YES THEO/26.9425,3.7322,-0.0306,0.9998307,-0.0184006,0 ACTL/26.9425,3.7322,-0.0306,0.9998307,-0.0184006,0 TARG/26.9425,3.7322,-0.0306,0.9998307,-0.0184006,0 THEO_THICKNESS = 0,RECT,SNAP = NO,$ AUTO MOVE = NO,DISTANCE = 0,$ FIND NOM AXIS = NONE,UPDATE VEC = 0.0184006,0.9998307,0,$ REPORT VEC = 0.0184006,0.9998307,0
CIR1 =FEAT/CIRCLE,CARTESIAN,OUT,LEAST_SQR THEO/<216.165,86.517,-434.485>,<0,0,1>,126.997,0 ACTL/<216.165,86.517,-434.485>,<0,0,1>,126.997,0 MEAS/CIRCLE,3,WORKPLANE HIT/BASIC,NORMAL,<267.305,48.877,-434.484>,<0.805371,-0.5927711,0>,<267.305,48.877,-434.484>,USE THEO=YES MOVE/CIRCULAR HIT/BASIC,NORMAL,<152.858,81.596,-434.486>,<-0.9969925,-0.0774986,0>,<152.858,81.596,-434.486>,USE THEO=YES MOVE/CIRCULAR HIT/BASIC,NORMAL,<247.375,141.816,-434.485>,<0.4915069,0.8708737,0>,<247.375,141.816,-434.485>,USE THEO=YES ENDMEAS/
cir2 =feat/circle,cartesian,out,least_sqr theo/<215.014,83.518,-437.202>,<0,0,1>,52.444,0 actl/<215.014,83.518,-437.202>,<0,0,1>,52.444,0 meas/circle,3,workplane hit/basic,normal,<235.424,99.98,-437.202>,<0.7783592,0.6278192,0>,<235.424,99.98,-437.202>,use theo=yes move/circular hit/basic,normal,<189.776,76.4,-437.202>,<-0.9624594,-0.2714258,0>,<189.776,76.4,-437.202>,use theo=yes move/circular hit/basic,normal,<234.056,65.49,-437.202>,<0.726196,-0.6874878,0>,<234.056,65.49,-437.202>,use theo=yes endmeas/ cir3 =feat/circle,cartesian,in,least_sqr theo/<217.52,101.337,-437.514>,<0,0,1>,5.946 actl/<217.52,101.337,-437.514>,<0,0,1>,5.946 meas/circle,3,workplane hit/basic,normal,<214.628,100.648,-437.514>,<0.9727633,0.2318008,0>,<214.628,100.648,-437.514>,use theo=yes hit/basic,normal,<218.354,104.191,-437.514>,<-0.2804749,-0.9598614,0>,<218.354,104.191,-437.514>,use theo=yes hit/basic,normal,<218.826,98.666,-437.514>,<-0.4391338,0.8984217,0>,<218.826,98.666,-437.514>,use theo=yes endmeas/ cir4 =feat/circle,cartesian,out,least_sqr theo/<215.01,83.516,-434.092>,<0,0,1>,22.939,0 actl/<215.01,83.516,-434.092>,<0,0,1>,22.939,0 meas/circle,3,workplane hit/basic,normal,<226.231,85.893,-434.093>,<0.9783064,0.2071631,0>,<226.231,85.893,-434.093>,use theo=yes move/circular hit/basic,normal,<212.874,72.247,-434.092>,<-0.186215,-0.982509,0>,<212.874,72.247,-434.092>,use theo=yes move/circular hit/basic,normal,<204.289,87.593,-434.092>,<-0.9347136,0.355402,0>,<204.289,87.593,-434.092>,use theo=yes endmeas/
ALIGNMENT/END
