Using Star probe
  • Using Star probe
    I want to use a star probe but I have no idea how to : create one, pick components and also calibrate one.
    I went to the CMM level 1 & 2 but they never showed in detail on how to construct a star probe.
    Any one has a learning source or something.?
    Multiple multiple threads on this, do a search. It's not terribly different from a normal probe.
      number 1 do you have any components? If not get the Renishaw book out!
      Cookie
        Look below at Similar Threads,
        B&S Global 544
        Using 3.7mr3
        Peace
        Greg
          F1 pc-dmis help file.
            Use the Probe description area to define the star probe. For example if a 5-way extension is added, Pcdmis offers 5 empty connections.
            Fill any or all of the needed connections. Pcdmis will always measure the lowest tip first (lowest in the Z axis).
            Hope it helps.
            sigpicIt's corona time!
              The tips of the star are numbered 1-5. T1 is pointing straight down at A0B0. If you rotate the PH10 to A0B90 and look at it end-on, T2 is at 3:00, T3 at 6:00, T4 at 9:00, and T5 at 12:00. To use tip 5 at A45B90, it would be T5A45B90.
              HTH
              v2013 MR1, v2015.1
              B&S Global 544, 555
              Mitutoyo A504 w/PC-DMIS
              Since 1994
              (Advice from my dad.)
                http://www.box.net/shared/static/9avdyzlv0v.doc
                http://www.box.net/shared/static/v464i35kxu.pdf
                And lastly this file will show you how to set to qual connection #2 and #4 at A90B90 and A90B-90 respctively.
                http://www.box.net/shared/static/z8v3louse0.doc
                These are higher level actions you are attempting. I see you are using 4.3mr1? If your SMA is current please contact the Technical Support folks for further clarification, 1-800-343-7933. I did when I needed to learn how to qualify a star probe.
                  Wow that is great info! Thank you so much.
                  I will try this out today to see if it works.
                    If it doesn't work check what you did, it works. May need to increase prehit and retract distances.
                    TK
                    sigpicHave a homebrew
