I have a call out of .125 Pitch thread / 3.25 Revolutions. I've never measured this kind of feature on the CMM. From what I've been seeing is that it can be done pretty easily. Could use some info! Thanks.
Measuring Thread Pitch
Use an autocylinder. Put the pitch in the pitch window. Your rows should be a multiple of the pitch apart. Cylinder diameter will be either the thread minor or major depending on whether this is ID or OD.sigpic"Hated by Many, Loved by Few" _ A.B. - Stone brewery
I don't think anyone is actually measuring thread pitch with the CMM. What you may be thinking of is using the pitch function to measure the location of a threaded hole. This allows the styli to hit on the same part of the thread for each hit. (IE. Crest, or just off the crest at intervals aroud the hole.)When in doubt, post code. A second set of eyes might see something you missed.
What part is it you want to measure the 0.125 pitch? The 3.25 revolutions? Or is it the thread form itself? I guess I shouldn't really ask as none would be a good idea on the CMM. If you simply want a rough (I mean rough) location reading then do what Wes said, otherwise do what J said. I say get an animated avatar and your problems will all go away.
I know it's cheap. but it will get us off your back
http://i62.photobucket.com/albums/h9.../underspec.gif
Save as.....sigpic
I'm getting the fealing you want to measure the actual thread for conformance to the thread spec with the CMM? You better hope it is a standrad thread that there are typically gages on the shelf for because you need a thread gage now, while you are making parts. I'm outta here man.<internet bumper sticker goes here>
Originally posted by UnderspecThis is a part that's about 2.8" in diameter. I don't have gage that size
The cost of the gage should be included in the job.sigpic
Alright if you must know how to do this...
First you need to get best-wire sized styli for the probe. Typically this is sized by (w = 0.5p x secant(1/2 thread angle). Thread angles are usually 60deg unless you are using British Threads then sometimes they are 55deg - you better double check which ones you have. If you can't find the correct sized tips then you can vary slightly but you will have to calculate the correction. The next thing to do is calculate the correction factor for the actual pitch diameter and the effective pitch diameter based on the corrected wire size and measured diameter. Once you measure the thread with your self centering scanning CMM, take the uncompensated diameter and add 2(sin(30)x(1/2(bws))). Make sure you scan a speed that will maintain a constant gaging pressure of 2.8 lbs - no wait that is if you are using wires, never mind that part about the pressure.Last edited by cmmguy; 08-14-2006, 05:27 PM.
by TigerSharkHi
I am trying to measure a threaded hole, I need use pitch, the problem is, when I input the Pitch value the circle will shift for...-
01-25-2008, 01:08 PM -
I've been asked to measure a pitch of a thread. I'm not sure how to do that, or if it's even possible?
05-16-2018, 01:07 PM -
by Mike BoeroHow do you use the pitch option for say 1/4-20 thread. What number would go in the pitch box and would you need more that 0 start and 360 end. Thanks...
06-20-2006, 11:15 AM -
by GEllsworthIts been a few years since I have used it, but I need to inspect perpendicularity of a threaded hole but I cant remember how to come up with the pitch...
04-01-2011, 11:01 AM -
by rem1187autodoes anyone know how to check the pitch dia. on an o.d. 2 3/8-5 api tapered thread?
03-18-2011, 12:02 PM -
