3.7mr3 Beta
I have several cylinders on a block. I go to the first one and take a plane around it, measure the cylinder and hit create. The probe goes straight to the center and down into it (the cylinders are like little tubes). I've checked and rechecked, tried several variations. the graphics look right, even the hits in the command parameters look right. Of course, when I'm looking at the graphics window (zoom in) the whole thing dies and I have to reopen PCDMIS. I've attached a pdf of the cylinder menu. Any thoughts? Seems like every time I do a cylinder there's some quirk that shows up.
PCDMIS has got to be the worst software I have used. I used MM4 for years and it was very stable, easy to edit, numbers did not change, when you wrote a program it was the same when you used it the next week or the next year. Quite frankly the only real plus I've found with PCDMIS is alignment is a lot easier and you can use graphics. These don't offset the headaches to me. Granted I've only used PCDMIS for about 2 1/2 years and don't pretend to be an expert but D*MN. I'm almost to the point of telling my company that I made a mistake recommending this and just go back to MM4.
Sorry for the rant but I'm very frustrated/p**sed off right now. I do feel alittle better to have vented.
