Text only report format
  • Text only report format
    I want the simple text only report format. I click the icon at the top of the report window to to switch it to TextOnly.rtp, and I still get the tabular format with boxes around everything and the graphical tolerance bars. How do I get my simple text only format back?
    2009 Release
    TIA
    Jonathan S
    pcdmis 2009
    G&L CORDAX RS-150 DCC
    B&S global 15-30-10
    DEA Delta Slant 30-100-15
    With the report window open right click in the body of the report > Edit Object > check the tick box at the bottom that reads "Use Text Mode Dimension Reporting"
    HTH
      http://www.pcdmisforum.com/showthrea...orting-problem
      or this is the problem. If they have it in 2009?
      sigpicstill core to you
        Thanks, but now it's all black text. How do I get the green and red text back?
        Jonathan S
        pcdmis 2009
        B&S global 15-30-10
          Try this (originally posted by James)
          http://www.box.net/shared/static/xoyv971zoz.zip
            I was able to get the color back in the text by opening another program, adding my default template to the toolbar and recalling the default from the new icon in my other program. I would still like to know how or why my text was all black and how to change it to color in the settings.
            Jonathan S
            pcdmis 2009
            B&S global 15-30-10
              Thanks lambo, that's what I was looking for.
              Jonathan S
              pcdmis 2009
              B&S global 15-30-10
                Thanks to James.
                  Is there a similar fix for 4.3 MR1 Release? I can't find the "reporting" section in the settings editor.
                  EDIT: Nevermind, I was looking in the wrong setings editor. This comp has 3.7 and 4.3 loaded. Looking for reporting instead of printing didn't help either.
                  Thanks
                  Sean Steele
