I keep getting watchdog fault - x-axis custom chip rate error.
I know that this is most likely caused by a dirty x-axis scale. I am going to clean the scale and it should go away as it has done in the past.
My question is this... When the error occurs motor power is shut off. The only way I have found to clear the error is a complete shut down and re-start. Is there a way to clear the error and get the machine going again without a shutdown? I can't seem to do anything after the error. I would at least like to be able to manually move the head away from any obstructions before the re-start.
It's Friday and the machine knows it! It always - always acts up on Fridays!
