Finding edge of radius
  • Finding edge of radius
    I know this sounds like a stupid question but I am using 2010 mr1 cad software and I am trying to get a edge of a radius of a part and I am having troubles pulling the dimension
    Not sure what you're asking, but if ti's as simple as the edge of a radius (from cir1)
    maybe something like:
    assign/v1 = cir1.x+rad
    create generic feature
    report location
    HTH
      ok what I am trying to get is from a center of a hole to the edge of the part which is a radius. What I have tried to do what takes point in the edge then create a circle but the it gives me is to the center versus the edge. I used cad++ in the past and I am thinking it was easier to pull the dimension
        If you are wanting the theoretically sharp edge as if the radius wasn't there you need to use "edge point" or "corner point".
          not sure if it's what you are after, but create a point from cir 'the hole' then create a dimension-->distance from that point to the outer cir (the radius) and under circle options check the radio button 'add radius'
          HTH
          • mconklin
            by mconklin
            I know this sounds like a stupid question but I am using 2010 mr1 cad software and I am trying to get a edge of a radius of a part and I am having troubles...
            06-30-2010, 12:16 PM
          • AuRules
            Edge point.
            by AuRules
            Just need a couple of questions answered about edge points. Never, ever used them but trying something for the boss who says this project is hot....It...
            12-01-2010, 01:01 PM
          • Liambo734
            Scanning Edge
            by Liambo734
            Looking for suggestions on the best way to accurately capture the edge point in the attached file. The rad is to small to accurately measure as a circle...
            12-17-2014, 08:26 AM
          • Liambo734
            Finding an edge
            by Liambo734
            I have a callout which is the height of a raw edge. One side of the edge is a plane, the other side is a free surface. The edge is the intersection between...
            12-19-2013, 11:59 AM
          • camaroman
            edge point
            by camaroman
            i have a flat circular part with a pocket in it and i need to check surf pts but i want to do it and a set distance from the edge. i cant construct a...
            08-11-2010, 02:42 PM
