I have a tube with a bore at each end. Outside of the tube is primary datum. Would you then measure the bore features as cylinders, (3d), or circles, (2d), to report postion and/or concentricity?
Position/Concentricity - Cylinders or Circles?
If you are aligned to the OD it should not make any difference.
If you want to know the orientation of the ID to the OD you would use cylinders.
If you just need location at each end circles should work.Lately, it occurs to me
2017 R1 (Offline programming)
Position: (3D) what dph51 said or I would measure both ends as cylinders and then report “From the worst end of axis” or “From both ends of axis” but never “From axis average”
Concentricity = Circular runout (sort of...): Concentricity is applied to each cross section therefore I would treat it as 2D….
HTH
Level to the O.D. datum. The only differences you're going to see in I.D. position or concentricity are if you measure as a circle the position of the circle will report out from its center along the datum axis. If you measure as a cylinder the position that reports out will be from the baricenter (sp?) of the cylinder along the datum axis. Coaxiality is a whole other can of worms and requires all cylinders.v2010 CAD ++ Global Image 121510
[QUOTE=lambo;292156]Position: (3D) what dph51 said or I would measure both ends as cylinders and then report “From the worst end of axis” or “From both ends of axis” but never “From axis average”
As Lambo says. Check the help file under position/axial feature
From Axis average > centroid of axial feature
From Start point > start point of axial feaure
From End point > at end point of axial feature
From worst end of axis > outputs from worst end case
From both ends > outputs position from both ends
by dennisgilpinThe question I have is what is the difference between measuring the concentricity between 2 circles (measured as circles) of the same diameter or between...
05-08-2012, 07:43 PM -
by dragonbladeHi
I have a box 6" x 6", with protruding OD cylinders 1" dia. each 2" long on the left and right. both cylinders are Dat...-
10-01-2008, 01:19 PM -
by ROBB OVERBEYi have a drawing that calls out the concentricity between 2 circles, i am using pcdmis 2013 (cause i haven't updated yet), but cannot figure out how to...
01-14-2016, 09:28 AM -
by dragonbladeHi
I have attached a picture of a part that I hope can be seen.
the small OD on the left and right sides are dat -A-'s. I measure...-
02-14-2009, 01:45 PM -
by TOP8PROAnother instance of my programmer and I butting heads. First off, I want to ask... Is an alignment needed to measure the concentricity of 2 circles? If...
12-06-2012, 09:43 AM -
