Hide Keyed in Dimension??
  • Hide Keyed in Dimension??
    Good Morning Folks,
    I have two "keyed" in dimensions that I assign to a variable, and then take the absolute value of them.
    I assign another variable that I use to add the first two together.
    I then construct a generic point and insert the last variable. So far, so good.
    How can I prevent the two "keyed" in dimensions from showing up in the report??
    In the dimension line, I have selected "None" for the output, yet it still shows up in my report.
    Thanks in advance for your assistance.
    Best Regards,
    ZydecoPete
    Edit prefs/edit window layout turn off comments
      T Miller,
      Thanks for the quick response; however, unfortunately this did not achieve the result that I was looking for.
      The two "keyed" in items still showed up in the report.
      Regards,
      ZydecoPete
        You can put them in as a "input" comment. Assign the comment into the generic point. You may have to turn the "report " in comment off too though.. Sometimes it defaults to report on and sometimes it doesn't
          Output Report, statistics, both, none. Look for something like that in the dimension block You want "none" You will see this in command mode for that dimension. The option is there for every type of dimension I believe.
          Craig
            OK here is what you need to do
            Change this:
            DIM 2 = KEYED IN DIMENSION  OUTPUT=BOTH
            AX    MEAS   NOMINAL    +TOL     -TOL      DEV    OUTTOL
            M    2.0050   2.0000   0.0313   0.0313   0.0050   0.0000 ------#-----
            to this:
            DIM 2 = KEYED IN DIMENSION  OUTPUT=NONE
            See what I did?
            Craig
              Hello Craig,
              Currently, my dimension line looks like this;
              DIM KEY12= KEYED IN DIMENSION OUTPUT=NONE
              The results still show up in the report. This is not a super big deal.
              I'm just trying to learn more about pcdmis. There must be a way to "hide" this little @@[email protected]!#[email protected]#[email protected]#$
              Thanks for your Input !!
              ZydecoPete
                Does it show up when you re-execute the program? I use that to keep regular dimensions from showing that I don't want to show and it works. I wonder if for some reason Keyin dimensions are treated differently. That stinks man.
                Craig
                  Use a marked set and unmark the section you do not want to report. -Maybe?
                    Get the data as a COMMENT~INPUT statement. You can use that data in variable too. Why didn't you show him that method, booger-boy?
                      Thanks for the advice,
                      Forgot to mention, I am using ver3.7mr3, reasonably stable.
                      Craig; yes I have tried to re-execute the program, and it still shows up.
                      Djayne; I am actually using a marked set. If I "unmark" the keyed in dimension,
                      then it will not ask me to "key" in a value, and therefore my calculated dimension will not work.
                      So in order for it to work, the "keyed" in features do need to be marked.
                      Thanks to All !!
                      ZydecoPete
                        If you do it as an input comment, it will still prompt you and it will carry it to a generic feature though. honest.. I do it all the time
                          I was thinking that next but I thought what he wanted to do could be done. I don't get it, I use the none option for "fake" dimensions in my bonus tolerance scripting that I don't want to show in the report and it works. I guess Keyin dimensions get a different treatment. At this point I'd do what Matt says and set a variable.
                          Craig
                            This message may be a duplicate, if so I apologize.
                            Yes, I have tried to re-execute the program. It still shows up.
                            I am also using marked sets. When I tried to unmark the keyed in features, then I am not able to input my required information to do the calculation.
                            Therefore, I do need to keep these features "marked".
                            Thanks to All for your assistance !!
                            ZydecoPete
                              Another vote for the Comment - Input version. It gives you much more control of something you hand enter. If you add numbers into the text prompt, i.e.- staing the tolerance to the operator, you may need to put quotes around the number.
