Construct Perp Plane
  • Construct Perp Plane
    I'm constructing a perpendicular plane which should have a vector of 1,0,0, but the actuals are way off, like 0.40125463, 0.0000012, 0.984312.
    My Datum_A is a plane in -Y (0,-1,0) and I'm leveling to it. I have a line with a vector of 0,0,1 so it's pointing in +Z. My construction is CONSTR/PLANE,PRTO,DATUM_A,LIN_B
    Shouldn't the resulting plane have a vector 1,0,0?
    Help!
    Global Advantage 12-22-10
    TESASTAR M SP25 4.3mr2
    Help!
    Wouldn't that line and plane be parallel? Just trying to visualize it -
      Originally posted by ir a programmer View Post
      Wouldn't that line and plane be parrallel? Just trying to visualize it -
      Yes they are parallel but the resulting plane should be perp to A and through B, yes?
        It should be - that is correct. What are the results if you reverse the features?
          Are you taking points in slow mode for initial alignments?
          I am fluent in three languages:
          English, Sarcasm & Profanity.
            I just took three manual points for a plane and took two points for a line. No leveling or alignment.
            Did keego's construction and walla - a plane perp to plane 1 passing through line 1.
            keego, you ain't got the right hat on today.
