do you use it? whats it do? what are the different 2D - 3D settings? mine is set to off...
Polar Vector Compensation
I used to use it before CAD was widely availble. Even back then though I stopped using it because in the earlier versions, 3.25 I think, when you measured a polar vector point from say your main alignment and then translated to an effective radius origin, reported that PR and answered yes to the question of "Do you want to send the nominals back to the feature?" it used to mess up your measurements. That has since been fixed (I'm pretty sure), but I still don't use it. I am just as effective (pun intended) measuring auto-vector points and then translating to them.sigpic
can someone explain this?
i opened the back-up copy of the program that got messed up, i saved it on cd rom a year and a half ago. run it in v3.5. it checks good, open it in v3.7 it checks good. same part same program??? was checking bad, is now checking good with the back-up program. crazyness. http://www.mmiclan.com/smilies/vb_icon_scratch.gif
TKsigpicHave a homebrew
Okay folks....Would normally research before bothering y'all but there's a machine sitting with MY NAME on it !..Anyway, I have a small section of a 1.00...
04-23-2009, 02:45 PM -
by UnderspecI have a cylinder facing the Y+ machine axis. I have the origin in the center established. Now I want to take random points on the surface and find the...
07-30-2007, 05:11 PM -
by Lee JohnsonInteresting new problem with version 2013 When I try to use auto features without cad and manually insert XYZ and IJK point Values everything changes...
04-04-2014, 12:37 PM -
by hemirunnerSay i have a 15° of a radius in a part, would there be any difference if I used CAD and vector points with snap turned on vs. auto circle feature? Would...
05-16-2013, 09:43 AM -
by John KuglerAnyone have an idea how exactly PC-DMIS calculates polar radius?
Just askin'.
TIA-
01-17-2008, 09:42 AM -
