Does anyone know what an offline seat for PC-Dmis Cad++ would cost?
Cost for an offline seat?
The following is a quote from a previous thread on the forum. "Instead, I have to purchase an off line seat for $14,900.00 just to be able to program away from the machine ". I believe this person, at the time, received a recent price quote. tlnzzPC-DMIS V3.5 MR1. CAD++
Global Image 574.
Windows XP
ASQ-CMI. - 1986
Journeyman machinist, August 1970.
Would it be illegal to make software that can open PCDMIS files and edit them?Like an importing features that can convert them to text files. Just an idea.
I also want to add that you can export the program into a .BAS script file. If you are a basic guru I'm sure you can edit it or program offline that way.I used to be high on life but I built up a tolerance.
Well, you can edit a program in word or wordpad.
All you have to do is have the program visible in the edit window. Go file-printing-edit window print setup-check the "file" box and "rtf" format. Click "OK" then hit F4. It will print your program to a file that can be opened in wordpad. You can go in there and change stuff around as you like.
I don't think there is a way to get it back into a format that PC-DMIS can use though.
by Curty_82Hello Im wondering if anyone knows if I can buy a used offline seat.. I'm trying to start a business and trying to keep my start up cost as low as possiable.....
04-02-2012, 05:46 PM -
by D.R.MossOur boss has been considering buying an offline seat and putting it on a laptop just for mobility.
Does anyone know how much an offline seat cost...-
10-13-2011, 10:28 AM -
Someone was asking me if you can buy PC-Dmis as a offline seat only??? I didnt think so but i was not sure, and i figured that you guys would know. Thanks...
06-29-2009, 10:49 AM -
This might be a little bit of an odd question, but what are capabilities and cost of an offline seat of PC DMIS for a CMM?
Reason...-
02-27-2015, 05:04 PM -
