Hello CMMers. I have a cad model translated to 3.7mr2. The cad origin is on 5 degrees. Another person had the same cad model translated into 4.1 and the origin was where the datums are. How does 4.1 do this????? Thanks for the input
sigpicRegards,
Donald Henger
B&S Micro Excel Pfx
3.5mr2 & 3.7mr3
PHH10MQ, TP20 & TP2
Country Rocks,But Bluegrass RULES!!!
You can translate, rotate, etc. the origin to wherever you want in 4.0/4.1 but simply importing it in the different versions shouldn't make a difference.
First thing I would definitely check the CAD import files and make sure whatever you are importing is the same CAD files as as different PC Dmis versions should import using the same CAD coordinates
I use ProE and most models have multiple coordinate systems saved in their native format, ie .prt
I have in the past on the same part saved a file off as IGES using one CAD cordinate system then realised the model was not correct,updated the model then re-saved but selected a different coordinate system thus when its gets into PC Dmis nothing lines up......just something to check
When I convert a 4.1 program back to 3.5mr2 the cad becomes dark and I cannot change the shade of the cad. Is there a setting that changes the cad when...
Hi everyone. Wondering if anyone has experienced any problems importing cad files in 4.1. Every time we try and import a cad file, you can expect to wait...
If I import a cad model and the orgin is out in space. Is there a way in PC DMIS ver. 2011 mr1 to change the location of the imported cad origin so I...
I have an existing program with CAD file which required using the transform function to adjust the origin & axis. I now have a new revised Iges file...
