When your executing a program there are colored lines running with the code.How do you turn the colors off.
4.1 COLORS
good question...I don't think you can. It is very hard to read/see the commands as they pass by with the color contrasting with the existing font colors. I do think it's cool to see the software using "look ahead" and color the code it as you go to see what is going on. Its kinda like the breakpoint mode only without the break/stop point.sigpiccall me "Plum Crazy"....but you only go around once!
Originally posted by Mike N.good question...I don't think you can. It is very hard to read/see the commands as they pass by with the color contrasting with the existing font colors. I do think it's cool to see the software using "look ahead" and color the code it as you go to see what is going on. Its kinda like the breakpoint mode only without the break/stop point.
i think you can turn it off but i dont remember where.
EDIT:
To change the background colors used:
1. Select Edit | Preferences | Edit Window Colors from the menu bar. The Edit
Window Colors dialog box opens.
2. Click the Auto Preview check box. This allows you to preview your changes
inside the Edit window as you make them.
3. Simply click the Edit button for the background or highlight color from the
Background Color area. A Color selection box will appear.
4. Select the new color, or customize a color by selecting the Define Custom
Colors button.
5. Click the OK button. The Color selection box will close.
6. When finished defining your colors, click the Apply button to see the changes
without closing the Colors dialog box.
7. Click the OK button to apply the changes and close the Edit Window Colors
dialog box.
The color changes will immediately be made.
by AJHVW93Is there a way to change the color of the text in the elogo.dat and logo.dat files? Its not in the edit window colors. Thanx
01-04-2008, 05:47 PM -
by Moore RacingMy Edit window, comes up all different colors...when I run a program... (like when You calibrate a probe.. colors)
Some clown got in here and...-
02-25-2015, 05:20 PM -
by JigneshHexagon installed 2017 version last year. 1. I clicked connect to see all function in setting editor, but I could not see current values. Could one...
07-11-2018, 10:26 AM -
by jkb_mcgI know I've discussed this before on here but I couldn't find it....
Does anyone have problems in 4.2mr1 with the dimension colors staying...-
08-18-2008, 03:24 PM -
by Lon FelsGood morning all,
I have always wanted to shared this with whoever would like to use it. A number of years ago I modified the colors of...-
04-10-2015, 12:03 PM -
