My height distance measurements from one plane to another are all coming out measuring 0. What am I doing wrong? How do I get the actual meas. distance?
Z axis plane to plane meas.
Originally posted by adamclinardMy height distance measurements from one plane to another are all coming out measuring 0. What am I doing wrong? How do I get the actual meas. distance?
Perpendicular distance between 2 planes.
Originally posted by Matthew D. HoedemanYou can also do the 2-D distance as parrellel to an alignment axis so you should be able to ignore the workplane plane (I think).
Originally posted by Matthew D. HoedemanYou can also do the 2-D distance as parrellel to an alignment axis so you should be able to ignore the workplane plane (I think).Bells and whistles!
TKsigpicHave a homebrew
by isahnI am beginner with PC.DMIS. I will create distance between two features ( plane vs plane,..) but i have disable relationship to Z axis. Please, how i...
08-21-2008, 05:18 AM -
by Slug DawsonWhy is there a difference in the way PCd calculates the distance from a plane to a point? Shouldn't a 2D distance from point to plane perpendicular to...
12-01-2009, 05:50 PM -
by norkamusFor the reference feature in:
Code:DIST2D({feat},{feat},{reference feature})
06-02-2016, 10:45 AM -
by mrogers95129Hi and thank you for looking at my question. This is an overhead view. I am trying to get a 2D distance from circle 2 to circle 1, or vice versa, in the...
02-10-2015, 08:42 PM -
by dfiola66I know when I'm moving around a part, I must switch workplanes to get dimensions normal to that plane. If it's an angled plane not normal to any workplane,...
07-08-2006, 10:00 AM -
