ok I am shure this is my fault. I installed 4.1 this morning. I renamed my folder to save the previous version so it would not be lost. It was 3.7 mr3. now my machine seems to be of about .05 of a inch in -X & -Y. I just moved 1 progam in to new folder to try it out and this was the first minor problem. do i need to move any of the old files to this new version? Or am I on the wrong track here.
v4.1 minor problem
You should have made a COPY of the older install directory, then installed the new version in the copy directory. There are probably MACHINE COMP FILES that you are missing now and that will make you out of calibration.sigpic
It will be in the SETTINGS EDITOR and it will depend on your controller. If you have a current SMA, your best bet would be to contact B&S and tell them you need INSTANT HELP (and if you are installing V4.1, you should be current). However, if you already had V3.5 or newer installed, the setting SHOULD already be set, the new install SHOULD NOT change it, but we all know that B&S likes to mess us all up by doing things the WRONG WAY.sigpic
by CorsairThe people from Tech- Support told us that we can run multiple versions of PC-DMIS.We start with 3.5 wich was O.K, then last month we loaded v 4.0 nothing...
09-28-2006, 12:05 PM -
by Bob PierceWe have just downloaded V4.1 but I get an error when starting PCDMIS "Unable to open download file"
I would think our adminstrator...-
03-02-2007, 04:10 PM -
by TestedI am in the process of upgrading from 3.5 to 4.3. The machine has a probe rack on it, can I just copy some files from the old 3.5 folder into the new...
02-25-2009, 11:06 AM -
First time posting here, but have been helped a lot by searching in the past (thanks everyone).
I had a hard drive die on PC running 3.7Mr1....-
02-21-2015, 01:28 PM -
Well, we actually talked the higher ups into getting a new high speed, powerfull computer and although I know this has been covered before on the forum,...
06-23-2006, 09:16 AM -
