attention all Scanners
  • attention all Scanners
    so I have a solid of this insert and i need to scan it been messing with on and off for a couple of days can't really figure out what approach I should take will attach zip of iges for your viewing pleasure Thanks again in advance!
    With good information you could get better feed back!
    With what I can see; measure plane, plane create intersect line. Measure plane create intersect line, plane - plane. Measure plane create plane - plane intersect line. Create center line between lines. Create center point, center line to plane.
    Now you should be able to align to plane line intersect point.
      sorry bout the lack of info this what i need to do we have this insert for which i made a solid from the vendor's print i want to scan it but not sure what type i'm thinking open line but what i'm looking for is how to figure out how to do the settings IE: pnts per mm also speed and so on i'm new to scaning
        What are you tring to scan????
          j.g...correct me if I'm wrong, but didnt you just take a B.S class in scanning?We are looking to you for answers.
            Trying to scan an insert for one of our machining center's
              You are correct took the class barley starting to use it need to get all the kiknk's worked out then hopefully i will be able to help you out!
                As for the points/per, that's up to you, I guess. I don't have a scanning head, I'm TTP scanning. For "tight" areas (high rate of change), I will go 0.25mm between hits, open areas (low rate of change) I will go to 1 or 1.5 or 2 for the spacing, for what appear to be flats, I will crank it as high as 5.
                  the inserts pretty small that's where i'm having the problem
                    Small probe (1mm or less) and a tight spacing, like 10 per mm if you are using a scanning head. Go even smaller if you have a smaller probe. Now, as we all know, NOTHING in this world is perfect. If your head and probe are not absolutely perfectly straight and square, then you will have to break it up into smaller scan sections so you can use a probe angle to ensure that you don't shank out. As an example, on a square block, use A15,B45 to do the "left" and "rear" sides, then use A15,B-135 to do the "front" and "right" faces. Sorry I can't get any more detailed for a scanning hear since I don't have one, all I can do is pass on my tricks for the TTP scanning.
                      Thanks for the info!
                      • JoBLOCK
                        Alignment question
                        by JoBLOCK
                        ok. I use to program the OGP vision scope, and as far as I remember when you do a 3-2-1 alignment, one would have to select a plane, and 2 lines, then...
                        10-09-2009, 10:08 AM
                      • ptedrum
                        Constructing a Feature?
                        by ptedrum
                        I'm trying to construct a plane perpendicular to another plane, I'm hoping someone can tell if there is and easy way to construct the plane with the contructed...
                        07-31-2007, 11:41 AM
                      • redmach
                        Creating a point at an intersection
                        by redmach
                        Hi All, I'm back on my CMM after about a year off from programming and I could use a little help. I have a small part that has a seal bead protruding...
                        12-08-2006, 08:23 AM
                      • mrnoname
                        Plane to Plane
                        by mrnoname
                        Hi,
                        I was wondering if anyone could tell me how PC-DMIS views a plane to plane dimension. What my boss would like to know is when you level and...
                        10-24-2008, 01:14 PM
                      • Guest's Avatar
                        Question About creating a plane?
                        by Guest
                        Got a question about creating a plane from a point hit?
                        I have this clip that has a hole for a bearing, and on the back side of this part there...
                        04-15-2010, 05:43 PM
