sp-600 scanning
  • sp-600 scanning
    We have a global machine using 3.7 mr 3 cad++ with a sp-600 scanning head and i was wondering why after I go into dcc mode alot of the options are grayed out mind you I have never done a scan before first time Thanks in advance!
    That does not sound right, but not sure. WHAT options are grayed out?
    The SP-600 is a scanning head and CAD++ is the full package (nothing else to add to PCdmis except for direct translators/interfaces), so I would think that EVERYTHING would/should be available to you.
      all that is available is linear open/close patch and rotary
        We had problems (with 4.2 and 4.3) greying out many icons for no reason. Reboot the PC usually brought them back.
        You should have every scan that was available in your version.
        _ _ _
        It's all pattern recognition.
          cursor in the right spot? make sure the dongle has all the mods installed, if I remember correctly you can check that in the custprog.exe in the pcdmisw directory.
            Some of options are only available with a CAD definition. If you don't have CAD, those options are greyed out.
              I've never seen that, lots of thinigs I do without cad, all the options are available to me, never had anything grayed out.
                You can see it with boundary scan, for example. it's available only with a cad, that define the way of scan.
                  Actually, I just double checked, in V3.7 there is nothing ever grayed out, but, without a cad file, there are things that are (some scan options) missing, NOT grayed out. Nothing is missing in AUTO FEATURES, with/without/manual/dcc.
                    well don't worry because I'm actually on my way to hexagon to get trained on scanning so hopefully i walk out with a little knowledge of what is going on
                      Originally posted by j.gonzalez View Post
                      well don't worry because i'm actually on my way to hexagon to get trained on scanning so hopefully i walk out with a little knowledge of what is going on
                      [ATTACH]5649[/ATTACH]
                        took the class was pretty col was the only one there so the instructor explained everything to me and answered my questions now my first project will be to scan a three start acme thread!!!
                          You should run custprog.exe and see if you have the CAD++ module installed.
