If your nominal size is from circle cir1 then insert "cir1.d-.25" into the nominal for a generic feature. Or you could put it into a comment. If it is from a location callout i.e. loc1, then use "loc1.d.meas".
You could create an offset point. Create a point offset without a reference feature with values of 0,0,0. In the edit window change one axis to your variable such as Var0. Then just dimension that axis on that point.
I have a dimension that it is imposible to get directly, i have to calculate the dimension measuring other fixtures, but in the report i want to show...
I have a tab that i need to construct a point on. cannot directly measure the point due to flash around the feature. I orginally simply measured a half...
How do I use pi in calculations? I've tried just typing PI, but that doesn't seem to work and I can't find anyway to assign mathematical constants, but...
