using datapage 3.33.Went to gather some charts for one part# and when I try to excute data for run chart or any other chart it gives me an error:unable to access database for read operation.All other databases work fine.Have been using this data base for a couple of years with no problems.Any ideas.
Question on datapage
Sounds like a read lock may be on the DB. You can try using the Editor to Unlock that database (Database/Unlock, browse to DB in question) or you can use MS Explorer to go to the DB directory and manually delete:
LOCKMGR.DBL
VISTA.TAF
*.dbu
Just make sure DP/Editor is not pointing to the DB at this time.
LOCKMGR.DBL
VISTA.TAF
*.dbu
Thanks,deleting those files worked.Thanks again
by roddawgWhat causes the following database error:
"Error: Unable to access database for write operation"
It scrolls through...-
06-08-2006, 03:46 PM -
by JJordanI just downloaded datapage v.3.33. I had version 3.32. The tech support said that it should write over top of 3.32 without any problems. I created...
10-13-2006, 11:03 AM -
by KronosEverything was fine and all of a sudden after running new part got error:unable to access database for read operation. Changed the xstats11 file name...
06-16-2006, 06:32 PM -
by AuRulesWhen trying to send data at the end of my program I get this error.
Has anyone seen this before and how do I fix it.-
11-21-2008, 08:21 AM -
by Randy NehfI am getting an error message from datapage after executing a part program when saving stats. This is the message, "Unable to access datapage for...
06-09-2008, 10:01 AM -
