when you open a new program an this probe warning comes up <see pic>, what is the "newer functionality" that may not be available? i know by expirience that if you hit yes then it will screw up your probe for the older version, but what does hitting yes do for the newer version?
running more than 1 version question?
Ya know, I don't think it really does anything. I think that it is a CYA from the people at Wilcox. I mean, the probes have been the same 'ole thing forever (and we all know they wouldn't mess with something like THAT, now don't we?), you would think that there wouldn't be anything new, would you?sigpic
As far as 4.0 and 4.1 are concerned it has to do with scanning I believe. They have a new scan called freeform. Maybe some other stuff too. Saving your program back from 4.0 or 4.1 to an earlier version is how to get your probe to be useable in the older version. I have been staying with 4.1 for everything now, but a little FYI each time you save back to 3.7 the CAD file will increase in size. I believe that they are addressing this issue or have.sigpic
I'm with Matt on this one..
I don't think anything should change with the probe. After all its just a graphic representation with a tip center offset associated with each angle.
What good reason would there be to change those two simple things from version to version?sigpiccall me "Plum Crazy"....but you only go around once!
by tnguyenHi.
I got a program from Supplier. But I can't open, the message say : Error, need to use the latest Version". Any idea ? Thanks
07-31-2007, 02:36 AM -
by Master ChiefIn recent dealings with BrownandSharpe, I have been told that the latest version is 3.7mr3. Does this jive with what you have been told? It seems that...
07-10-2006, 12:14 PM -
by BKulpa
I have 1 machine using V4.1 which asks if you want to update the probe to the latest format every time we open a program.
I dosen't...-
02-19-2008, 10:55 AM -
Good Friday morning.
I need some help here. Here's the situation. I've been running 3.7mr2 on a B&S ONE with TP20 on a PH10T. Life...-
09-15-2006, 09:01 AM -
by gsepanWe currently installed Version 4.0 on 3 of our machines and although it has some tremendous capabilities it is plagued with bugs. Square Slot Auto Feature...
05-24-2006, 10:51 AM -
