PH10T or PH10M
  • PH10T or PH10M
    what are the differences between them. I got a quote on both from B&S to submit to manage ment and thay are going to ask what the diff is and i dont know.
    TIA To all that reply
    Global Status 777 PC-DMIS 2014
    Windows 7
    ever stop to think and forget to start again?
    http://resources.renishaw.com/defaul...terms=ph10+ph9Try this site:
    PCDMIS 2012
    Windows Office XP
      I think the ph10m will fit up inside of the Z rail giving you a few more inches of measurment in the Z over the ph10t
        I believe Craig is correct.
        T King
        sigpicHave a homebrew
          PH10T has a M8 threaded hole for mounting the probe
          PH10M has an autojoint mounting and more torque so it is capable of using scanning heads.
          JCTB
            We have PH10MQ which is in the quill allowing more z clearance.
            Time for the Trolls to leave.
              From the renishaw site: http://www.renishaw.com/client/produ...h/PGP-55.shtml
              PH10M
              The PH10M and PH10MQ can carry long extension bars and complex probes such as SP600M or TP7M. The advantage of the highly repeatable autojoint is that it allows rapid probe or extension bar changing without the need for re-qualification.
              PH10MQ
              The PH10MQ is a variant of the PH10M that allows the motorised head to be attached directly to the quill with the B axis of the head inside the quill itself. This option provides a neater and shorter probe mount, with only the A axis protruding from the quill.
              PH10T
              The PH10T is an M8 version of the PH10M. All M8 threaded probes and extension bars fit directly onto the head. The PH10T is fully compatible with all of Renishaw's stylus and module change systems.
                The PH10M is the "Multi-wire" auto-jointed head. Use as described above. Replaces the PH9A
                The PH10T is the basic head which replaces the PH9
                If you want the probe to fit in your quill then you need the "Q" model.
                The real question is which head are you replacing and what will you be doing with the CMM. Changing to a PH10M from a PH9 is pmore expensive that simply the delta between the probe heads. It may require rewiring your cmm with a new "mulit-wire" cable. Make sure you get the full quote and ask questions...
